Need a more solid answer
Old Aug 1, 2013 | 09:03 PM
Blue_05EVO's Avatar
I've searched and searched ! I've read a lot of different threads on the cobb ap ots maps.
My mods are
A basic cone mod with an AEM dry flow
And a tsudo v2 exhaust from Dp back ( no cat)
AEM uego
Prosport boost gauge
My question is simply can I run a stage two map with the SF cobb intake option ?
I'm assuming I can run a stage two map period since I have no cat and am free market from down pipe back
I've read that the sf is no the same as any cone mod and I've read that it is.
Experienced members I would greatly appreciate some help.
Old Aug 2, 2013 | 11:59 AM
Blue_05EVO's Avatar
Bump
Old Aug 7, 2013 | 01:20 PM
ikt's Avatar
ikt
you could run it and see what your AFR's and LTFT are
Old Aug 7, 2013 | 07:04 PM
Blue_05EVO's Avatar
I've got this problem solved the stock intake gives me ltft of +\- 2% and my afr is 11.3-5 at wot!
Now I'm trying to figure out how to get rid I my 28.5 psi boost spike the lwg map is 22 psi and the normal spikes 28 with 2-3 counts of knock sum.
Old Aug 8, 2013 | 11:25 AM
ikt's Avatar
ikt
it always spikes up that high I wouldn't worry about it
Old Aug 8, 2013 | 01:10 PM
Blue_05EVO's Avatar
I've hear that but it is my dd and I don't like having 2-4 counts of knock in the 4-6 rpm range.
I feel like the power just isn't there though. It's running a pretty safe afr and I'm sure the timing is lower being an ots map. So I figure the high boost spike is causing the knock sum
Tony Harris
Cobb AccessPORT
Mar 12, 2017 07:10 PM
jmoney2001
Cobb AccessPORT
Oct 6, 2016 10:28 AM
alexn103
Cobb AccessPORT
Jul 27, 2015 11:45 AM
userwave
Cobb AccessPORT
Apr 20, 2012 11:50 AM
GetterDragun
Oct 19, 2010 07:39 PM
