Having problems with COBB SF Intake!
Old Sep 18, 2013 | 07:41 PM
anglaenan7's Avatar
So, long story short, I have a xle cobb bpv (personal preference) and the cobb sf intake. I am having problems with idling. When my fan starts going on the radiator, my rpm's drop to 500-800 and will sputter. When my fans don't run, it idles just fine. Has anyone had any problems with yours? of course my check engine light turned on as a vacuum leak and that was taken care of, but it also showed a random misfire. Is there any advice what to do?!
Old Sep 19, 2013 | 07:43 AM
Slyy's Avatar
Take a picture of your engine bay with the intake. Sounds like a common problem with intakes that don't have a heat shield.
When the fans kick in the air blowing into your intake causes the idle spike problems.
There are threads on the forms about this.
Old Sep 19, 2013 | 09:35 AM
zanelefko's Avatar
heat shield issue, had the same problem with my ets before I put the shield on....the fan blows hot air directly on the filter element which causes the idle bounding.
Old Sep 20, 2013 | 07:25 AM
anglaenan7's Avatar
I just saw a photo of putting the front of the stock intake infront of the cobb one works really well. I think I will temporarily fo that until I get a different one. Any thoughts on the K&H?
Old Sep 22, 2013 | 10:25 AM
IRPerformance's Avatar
I would get some sheet metal and fabricate a heat shield. The sudden hot air from the fans entering the intake is throwing off the maf.
Old Sep 23, 2013 | 12:48 PM
zanelefko's Avatar
ETS comes with a heat shield and I love mine
europaul
Oct 11, 2016 02:35 PM
boyvang
Jul 16, 2015 07:17 AM
EvOXKanG
Feb 12, 2015 10:08 AM
Evolution (se)X
Cobb AccessPORT
May 30, 2014 01:24 PM
JerseyEvox
Evo X How Tos / Installations
Nov 26, 2009 02:51 AM
