Estimated #'s after tune??
Old Jan 2, 2014 | 08:23 AM
2012evogsr's Avatar
Hey I was just wondering what numbers I should be around when I have my '12 GSR tuned within next few days. The list of Mods I have are:
Injen Short Ram w/UICP
Grimmspeed 3 Port EBC
Tomei Widemouth Downpipe
Speed Circuit Test Pipe
Tomei Expreme Ti Catback
Perrin BOV
Comp Clutch Stage 3
I seems that the car stock tune is about 240whp from what I have seen and looks like the estimated numbers could be around 330-350whp.
Is this true with what everyone else has seem? Any input would be greatly appreciated.
Also the exhaust was installed a few days ago and everything was running ok and i noticed NYE it threw a check engine light? any ideas if it is a sensor or because it needs to be tuned.
Thanks.
Old Jan 2, 2014 | 09:04 AM
Sev's Avatar
Sev
320-350 and about the same range in torque. Obviously this depends on the tuner and the dyno. I made 336/347 on a Dynapack with the same mods minus the DP.
Old Jan 3, 2014 | 06:07 AM
2012evogsr's Avatar
Ok no problem, so regardless depending on what way you tune the car, everyone is seeing roughly the same numbers.
Also, I went to autozone and they ran the code for me and it came back as a turbocharge/supercharger overboost malfunction. I was told to just disconnect the negative terminal from battery to clear it out and so far nothing came back. The car is getting tuned next week so I will just take it easy and stay out of boost (if thats possible lol) to clear everything up. Thanks for your input.
Old Jan 4, 2014 | 02:58 PM
ah.evox's Avatar
I had similar mods and I was able to make 338/345
Gan-san
11
Nov 4, 2015 11:26 AM
DrivelineSales
Apr 17, 2013 05:27 PM
Buru_EvoX
Evo X Dyno Results
11
Apr 26, 2012 02:34 PM
BlackEight
Jan 23, 2012 07:54 PM
l2r99gst
Nov 15, 2007 05:35 PM
