Heelp
Old Mar 4, 2014 | 01:28 PM
Mievo4-8's Avatar
Heelp
I am new to evos i just bought a evo 4 with a evo 8 engine fitted
At idle the ingine presure light flickers wen the engine is hot, at idle it sits just under 1000 rpm
If i rev it to 1100 rpm tbe light goes out need some advice plees thank you
Old Mar 5, 2014 | 02:21 PM
zebra4's Avatar
First thing i would do, is hook up a mechanical oill pressure gauge and see what the oil pressure actually is.
Old Mar 5, 2014 | 05:53 PM
zebra4's Avatar
Also, low oil pressure may indicate worn main bearings. Since you bought it used i would check either way.
Old Mar 6, 2014 | 01:57 PM
Mievo4-8's Avatar
I changed the oil presure switch and the light has gone out thanks for ure help
Old Mar 6, 2014 | 07:57 PM
Thomar's Avatar
Yeh, the ralliarts used to have that problem. Oil pressure switch would eventually fail and cause the low oil pressure light to come on during idle.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
97evo4
Mar 8, 2015 05:51 PM
hurdle18
Feb 23, 2015 07:26 AM
Ogrodii
Feb 11, 2015 03:51 PM
Mievo4-8
Mar 5, 2014 09:45 PM
