Weird codes: P0172 & P0365
So here's the skinny. Just installed an ETs kit and got tuned today. Tuner is legit and made a nice 485/373. Shop was 100 degrees and 40% humidity.
Upon starting, a little oil around the hot side/downpipe burning off. Assumed it was turbo assembly lube, etc burning off. Drive to the shop proved that and no more smoking or oil visible. I had the exhaust cam sensor wrapped in heat wrap for protection.
Maybe 10 runs on the dyno. Maybe more. Got dialed into the above power at 26psi. No knock, nada. I drive home and about 5 miles from the shop, I throw an SES. Back to the shop, no visible breaks in the cam sensor. Clear codes, on my way. Again, 5 miles away, SES. Same codes. Too rich and exh cam intermittent.
I cleared the codes at the house but keep returning. I'm thinking upstream O2 is fouled with oil. The cam sensor hot. But, happened again, both codes, after 6 hours of sitting.
Going to see my tuner tomorrow but any ideas in the meantime?
Thanks for the replies. idle AFR's bounce from 14.3-14.9.
I picked up a cam sensor shield from Kozmic and clocked the turbo just a bit back towards the FW and it seems like it's running well now.
Sorry I didn't post back sooner -- it's been a crazy month!
reboundicon
May 3, 2017 11:51 AM
