Help E85 timing
Old Sep 8, 2014 | 03:55 PM
JonGonzo's Avatar
Question Help E85 timing
I was hoping someone with more knowledge than myself could take a look at my e85 timing map and let me know what you think about it and help me out. There is a lot of info for evo 8-9 e85 timing maps but not too much for Evo X.
I took a Cobb stage 3 93oct map and changed out the MAF scaling, injector latency, and injector scaling. MY scaling is pretty much spot on with STFT and LTFT right around 0.
Mods:
AMS short ram intake
Map UICP
Cobb 3 port
Cobb AP v2
ETS testpipe
ETS V2 quiet
FIC 1100s
DW 65c
comp clutch stage 4 (unsprung)
http://s1331.photobucket.com/user/Jo...5679b.jpg.html
Old Sep 9, 2014 | 04:56 PM
JonGonzo's Avatar
Come on guys
Old Sep 15, 2014 | 07:22 PM
3000GT-GTO's Avatar
Although I never tried e-85 my self but your timing seems about right from what I read on forum. I see your running 21 degrees up top 8 9 peak torque that's what I use race gas also. I tried to keep timing within 3 degrees of each other, some spot on your map appears to jump more than 3.
Old Sep 21, 2014 | 12:48 PM
acidtonic's Avatar
It would help if you mentioned what load you hit.... then we can see your path through the map.
Old Sep 22, 2014 | 10:26 AM
JonGonzo's Avatar
After this log I took out one degree of timing in the upper range and added some fuel from 3000rpm to 4300rpm.
evotuner04
For Sale - Cars For Sale
Dec 30, 2016 09:19 AM
Strictly Modified
Mar 27, 2016 08:06 PM
JohnBradley
Evo X Dyno Results
22
Jul 7, 2015 09:23 AM
dsm25psi
14
Nov 20, 2014 07:21 PM
anthonyrb98
33
Oct 22, 2013 05:28 PM
