AEM UEGO logging help...
Old Jan 19, 2015 | 11:38 AM
Fawkz's Avatar
Hey guys, ive been working on this damn serial connection for my AEM UEGO all day and its at the point where I'm getting really aggravated with it.
I followed the instructions here: http://www.evoxforums.com/forums/showthread.php?t=21747
The problem is whenever I try to log it in Evoscan it just shows 0.
Ive tried so many troubleshooting things... I have the bit rate set to 128k, I have it on com port 3, I have evoscan set to read com port 3 and its set to the aem gauge (ive tried all 3 AEM gauge options just for good measure lol, none work at all)
I'm using the gigawire serial->USB cable from radioshack. I installed the drivers before plugging in the cable etc, even tried re-installing the drivers. Cable says its compatible with windows 7 which I'm using. I mean my PC recognizes it and it shows up in my devices..
I figured maybe it was my wiring, but NOPE, I ran a volt meter to the db9 connector I wired up and it reads the correct voltage from the correct pin.
Getting frustrated with it not working and have no idea what to do
today I bought 2 other brands of cables, none of them have worked. Yet Im still reading voltage just fine from the female serial plug...
Old Feb 3, 2015 | 10:18 AM
ikt's Avatar
ikt
are you logging directly off the AEM? If so, Evoscan usually picks it up just fine. If you need help with wiring a direct connection shoot me a PM
Old Feb 11, 2015 | 07:03 PM
BoostingHard's Avatar
I hate logging afr through serial to usb converter it sucks my computer screws up drivers every now and then.....and I hate fixing crap like that
just do it through rear o2 sensor to get rid of those head aches
Old Mar 12, 2015 | 10:39 PM
Justnii's Avatar
In EVO scan make sure to pick AME UEGO 9600. Then select the COMPort.
dxbtune
Sep 20, 2023 06:03 AM
babaz7
Mar 10, 2016 07:17 PM
PATRICK B.
Mar 11, 2015 01:51 PM
fantrman
35
Jun 13, 2012 06:24 AM
SBR INC
Evo 'For Sale' Electronics / Lighting / Audio
111
Aug 3, 2011 07:48 AM
