Estimated power with these mods?
Old Oct 7, 2015 | 11:19 AM
Gan-san's Avatar
Hey guys, any guesses how much whp will I be making with these mods tuned on pump gas? And on E85, will easily go beyond 350+whp right? Here's what I have (only thing installed right now is the exhaust):
Ets 3" ic
Ets tp
Ets dump o2 dp
Ets uicp
Ets v2 extreme exhaust
Aem cold air intake
ID1000cc injectors
Aem fuel pump
GS 3 port
Old Oct 7, 2015 | 11:28 AM
evostanman's Avatar
You might be in the ~330-340 whp range on pump.
On E85, ~380+ whp
Remember this, dynos are different and numbers are numbers. East coast dudes freak out when seeing west coast tunes because of the #'s.
My tune reads 15% lower than others soooo yeah.
I recommend going with Walbro 255 pump for your E85 fueling needs and filter, ya da ya da ya da!
Also, I didn't see a intercooler in your list, did you forget it or you didn't upgrade?
Old Oct 7, 2015 | 11:45 AM
Gan-san's Avatar
I'm still debating if I should spend more $ considering the price of an aftermaket IC is equivalent to a dual map tune already. The stock ic should be good but I know having it upgraded will definitely make a difference. And deciding which tuner to go to is another story. There are a few reputable ones near my area but have not decided yet.
@evostanman - what are your mods if you don't mind me asking?
Old Oct 7, 2015 | 12:09 PM
e_kobz's Avatar
Between 330 - 345whp on pump gas. 380 - 390whp on E85.
Old Oct 7, 2015 | 02:16 PM
evostanman's Avatar
I was debating too with the IC and decided not to go with it at the end because the stock one is great for the power i'm pushing. I also did not get the down pipe because I still have the stock turbo and the gains would not have been much... so I saved some $$ there. I'll be getting my dp once i upgrade my turbo. Are you in California?
My mods are: Depo tp, Invidia N1, ETS intake, ID1000, Walbro 255, GS EBC, stock dp & ic.
Old Oct 7, 2015 | 03:47 PM
e_kobz's Avatar
Intercooler makes a huge difference in AZ. Only reason I did the downpipe was because I wanted the dump the LICP is the only bolt on I haven't bought yet cause I feel it's not really needed. Even when I upgrade to the MHI-18K I'll more than likely still keep the stock licp.
Old Oct 8, 2015 | 08:09 AM
evostanman's Avatar
In crazy hot areas, yes upgrade your ic.
I'm probably going to wait and save up for the ETS T3 kit Everything all at once
Old Nov 2, 2015 | 08:14 AM
Gan-san's Avatar
A little update on the mod list. I just bought an ETS intercooler since it would definitely be beneficial to gaining moar power!
Old Nov 2, 2015 | 01:39 PM
juan.c.olivos's Avatar
Do you know for sure if you will go with e85? Just curious because I made around 340 with these mods. You won't need the injectors unless you go bigger turbo or e85.
Old Nov 3, 2015 | 01:50 PM
Gan-san's Avatar
^Yeah, I will either be going the flex fuel route or pump gas/e85 tune.
Old Nov 4, 2015 | 04:55 AM
The you will probably get around 380-390 whp with e85. By the way I dont think our Evos can be true flex fuel. I dont think theres a solution for the part when there is a bit of both e85 and pump.
Old Nov 4, 2015 | 11:26 AM
Gan-san's Avatar
^Actually 5150 Racing (So Cal based) are offering that option now for Evo X's only I believe at the moment. Check out their website/FB/IG page. And yeah, close to (if not) 400whp is what I should be expecting or hoping with E85.
Celica2EVO
Oct 29, 2007 06:51 PM
kryptonitex
Jul 29, 2007 12:06 PM
titaniumkingpin
Turbotrix Racing - Edison, NJ
12
Nov 30, 2004 05:35 AM
ZeroFrost
24
Jul 23, 2004 05:45 AM
