COBB Stg1 K&N Typhoon Calibration
Old Jan 1, 2016 | 03:24 PM
Mike Barczynski's Avatar
Exclamation COBB Stg1 K&N Typhoon Calibration
Hey!
I put on my K&N Typhoon intake earlier today, I took it for a spin with just the plain stage 1 map I already had loaded... The intake sounded like crap in low and mid range rpms, so I pulled over and reflashed to the map I redid myself as according to the Cobb intake calibration video.. the car was getting wayyyy too much air and nearly shutting off in idle, so I reflashed to the ots stg1 and went home to fix the map.. This time with the "fixed" map, the car shut off a second after I turned it on... Help? Does anyone have a tune I could use?! Anyone have a similar issue!?
Old Jan 2, 2016 | 10:35 AM
AngryEvo's Avatar
I think for one you may have had a leak in the intake somewhere. Secondly you have to give it time for the ecu to learn the new parameters. If you did everything right with the AP then it should be fine. I'd reinstall, double check for leaks, and go from there. Or take it to a tuner.
Old Jan 8, 2016 | 11:16 AM
StevenTranSSK's Avatar
I'm using the Stage 1 +SF map and recalibrated it to the K&N intake and it works fine for me, I did have a small leak which caused it to shut down in the beginning as well.
Old Jan 10, 2016 | 05:06 PM
Dandbest's Avatar
I just put on a k&n typhoon intake on my otherwise stock FE, and it has no issue holding idle or anything else. Yes, its loud, not quite sure I like that, but the car seems more responsive, so it may stay. I need to figure out who's gonna tune it, and if I should go open source or accessport.
trpotts
Cobb AccessPORT
13
Mar 11, 2013 01:50 AM
BoosterX
Nov 8, 2012 04:39 PM
skifreakjay
Cobb AccessPORT
12
Sep 29, 2012 11:25 AM
Sschmuve1
Oct 13, 2009 09:56 AM
617G
Evo X Dyno Results
Apr 20, 2009 10:08 AM
