Going from UR mini muff to ETS test pipe
Old Jan 27, 2016 | 05:30 AM
ChipperEvo's Avatar
Hey all,
Sorry for the noob question but bare with me.
I currently have a UR mini muff test pipe and a Magnaflow CBE (it necks down to 2.5 in the rear). I purchased a ETS test pipe and want to change the exhaust out to a full 3 inch exhaust. Will I need a retune for this? I am pretty sure I don't need one but just wanted to check.
Thanks
Old Jan 27, 2016 | 06:26 AM
e_kobz's Avatar
Originally Posted by ChipperEvo
Hey all,
Thanks
I would to get the most out of your setup. It'll throw the tune off a little bit
Old Jan 27, 2016 | 06:49 AM
ChipperEvo's Avatar
is it, it is going to throw it off and your engine is going to blow or you will lose some power?
Old Jan 27, 2016 | 06:51 AM
e_kobz's Avatar
It's not gonna blow up
Old Jan 27, 2016 | 06:59 AM
alsong2002's Avatar
if the test pipes are the same diameter then you will not need a tune. it will run better if get a new tune becuz regular test pipe has a slightly better flow than the mini muff one.
just watch out your AFR.
Old Jan 27, 2016 | 07:14 AM
ChipperEvo's Avatar
ChipperEvo
Nov 7, 2017 01:35 PM
Turbo01s2k
Nov 25, 2014 06:58 PM
pcasso87
South Region
Oct 22, 2010 10:23 PM
EvilDylan
15
Aug 11, 2004 11:05 AM
