Is this normal for ID injectors?
Old Aug 3, 2016 | 02:29 PM
Burnhad91's Avatar
I have my HO fuel map set up as a target table and use my calibration map to correct any deviation in afr. I seem to recall a post a while back about having to pull 5-8% fuel in higher rpms when using certain Injector Dynamics injectors and that it was normal. I'm not 100% convinced so I had considered a load calculation issue but I don't think that is the case since load is dropping slightly in that area which should lower the fueling required in the area. So is having a fuel calibration map that looks like this with ID1000's considered normal?
Old Aug 11, 2016 | 03:06 PM
Burnhad91's Avatar
Anyone want to take a look at my rom maybe? Any help will be appreciated
illogicalmind
Nov 16, 2014 05:56 AM
chrylaser
Oct 17, 2013 11:51 AM
mexicanevo
West Region
Apr 26, 2007 02:05 PM
NoTiGuY
Nov 2, 2005 05:17 AM
tullio
Lancer Troubleshooting
Aug 8, 2002 12:21 AM
