P0365 Code thrown..... Just bought the car
Old Aug 16, 2017 | 07:58 AM
Woostopher's Avatar
So This code came on as I was warming up the car yesterday and traded in a car before this that constantly had CEL. Im just so tired of Check engine lights. ...
Regardless, this code is for the Exhaust Cam sensor.
looking into it apparently it gets too hot ?
Do i have to replace this sensor already? car only has 25k on it.
I ordered the heat shield for the sensor for now. I cleared the code and running on my stock tune atm just for safety precauton.
Old Aug 16, 2017 | 11:13 PM
4b11slayer's Avatar
Hopefully its just the sensor and not wiring or mechanical like a cvvt or cam. Or sludged oil galleys.
Old Aug 17, 2017 | 06:45 AM
Woostopher's Avatar
it is tuned. all bolt ons. Nothing internal. Upper and lower hard pipes and 3.5 ets Fmount, intake kit, Ams Downpipe, test, to hks hipower single. cobb, all on dynojet.
its making around 330 and the pressure spiked yesterday to 27 lbs. I am a little scared b/c rn i have the orange triangle with the !..... but i dont have tpms sensors in so mitsu said that it was cause of that.
Old Aug 17, 2017 | 06:59 AM
4b11slayer's Avatar
You can start by clearing the code. And swapping the sensor. You might be able to swap intake and cam sensors if theyre the same part number.
Re test drive and see if the code returns. If it does it still the same cam or did the code change to opposite cam?
Old Aug 17, 2017 | 10:57 AM
Woostopher's Avatar
So, as a newbie, where is it located? and I bought a heat shield for it as well
bone100
Sep 18, 2013 06:57 AM
corey54321
Feb 25, 2013 05:09 PM
silverghost
May 2, 2009 07:12 PM
SavEVOIX
Feb 15, 2009 12:58 PM
zupber4930
Jun 24, 2006 01:04 PM
