Irregular idle after bricking eco
After recovering my ecu after i bricked it the CEL come on and has high idle on start up.ive checked the vac lines and i have tried different tunes and no change.the rpms bounce around 1k when in neutral while moving and are normal as soon as i come to a stop.has anyone experienced this before or know what the cause could be?
You can also force a re-learn.
Evo X Electronic Throttle Valve (ETV) Relearn Process
1. Start the engine and let it warm up. Use the MUT-III to confirm that the engine coolant temperature
exceeds 85 C (185 F). The A/C switch should be OFF for this procedure.
2. Repeat the following step 3 times:
Turn the ignition switch to the OFF position and wait at least 10 seconds.
Restart the engine.
Leave the engine running on the third start.
3. Allow the vehicle to idle for a minimum of 15 minutes.
Restart the engine.
jos
Mar 8, 2014 07:19 PM
_EVOlved_
12
Jul 25, 2007 04:03 PM
