Pre-existing Tephra
Old Dec 23, 2019 | 08:31 PM
Warhawker's Avatar
Pre-existing Tephra
I bought an SE that's had lots of mods done to it, and tunes. I had it flashed to a basemap 93 octane so I could drive it back home. I intend to tune it myself.
I know it has a tephra mod, because twice I've seen the MIL flash on a pull indicating knock, which is Tephra mod feature. I have not tuned any cars before, but have a lot of "book smarts" on emissions and performance.
Before I plug my cables in, and read whats in my car into ECU flash, is there anything I should know before hand? I have no problem purchasing it if I have to, but I'm not sure if it's a hard flash that modified my ECU, or if I reflash it with my own MAPs I'm going to lose the Tephra functionality.
Thanks
Old Dec 24, 2019 | 03:24 AM
crimson red's Avatar
(I guess you bought a second hand car) If you have a TephraMOD pre-installed on your car, you can read it, modify it and write it using ecuflash without losing the functionality of TephraMOD. But if it is V2 or V3, I think you should buy it from tephra to get supports by him.
Old Dec 24, 2019 | 11:14 AM
Warhawker's Avatar
Correct, it was originally built by a board member and traded in this community. The owner before me ran E85 and slipped the SST clutches, then dumped it at a dealer in Florida.
Even if I drop 7k on clutches, a heated sump, tune, and all the good stuff, it's still a good deal.
Thanks for the info. I just want to get the car running better till I get can get it to Kozmic in the summer. I only have 91 up here, so I want to pull the timing back.
Old Dec 25, 2019 | 01:29 AM
If the SST slipped by the car's torque, the new parts may be better with enhanced SST clutches.
just in case.
You should first read and save(backup) the pre-installed rom with TephraMOD function with ecuflash.
Editing and writing it will not erase the function of TephraMOD. But once you write a rom without TephraMOD, of course, the function will disappear.
You can check whether a rom has TephraMOD function or not by looking at the ID. (For example, 52680122 has TephraMOD-V1, 52680322 has TephraMOD-V3, and 52680022 is without TephraMOD.)
Old Dec 25, 2019 | 04:18 AM
Warhawker's Avatar
With my mods, Kozmic recommended the 12 disc clutch. I wanted to retain some driveability and longevity so they recommended against the 14 disc.
So the 6th digit indicates the version, with 0 being non existent.
Very good info, thanks a ton for clearing that up for me. +1
krypt952
Jul 19, 2016 07:35 AM
letsgetthisdone
Sep 18, 2015 01:26 PM
wreckleford
Aug 27, 2014 06:12 PM
Babs
Feb 7, 2010 07:08 PM
fireroasted
Mar 14, 2009 12:16 AM
