Need an XML
Old Sep 16, 2015 | 06:16 PM
LetsGetThisDone's Avatar
Need an XML
A friends Evo X was tuned by a reputable tuner who I won't name. It has a tehpra V2 ROM that was fully paid for, and the tuner won't give us his XML. And we can't flash the car with any other ROM's. The guy is extremely difficult to get ahold of for little fixes like cold start issues, so my friends wants to switch tuners, but can't unless we can define his current ROM, or bench flash the ECU back to accept regular ROM's.
If I provide the ROM, is there anyone that write an XML def? Thanks.
Old Sep 16, 2015 | 08:25 PM
kaganader2's Avatar
Registered User
You just need access to the protective memory to make a full write to the ecu through the obd2. requires a registry edit on the laptop to do so.
Def tables for the v2 roms are made by David. What year is the Evo?
Old Sep 16, 2015 | 08:50 PM
Need an XML
It's a 2014.
I have an 8, so I'm not familiar with the X stuff. You'll have to describe the registry edit to me, unless it's something in can google.
Old Sep 17, 2015 | 07:55 AM
kaganader2's Avatar
Registered User
Make a reg entry file from notepad, ends in .reg with this in it if you want to flash over a v2 rom
[HKEY_CURRENT_USER\Software\OpenECU\EcuFlash\flashi ng\mitsubishi]
"protect low memory areas"="false"
I do not have the def for v2 2014+
Old Sep 17, 2015 | 09:34 AM
So, I save it here: [HKEY_CURRENT_USER\Software\OpenECU\EcuFlash\flashi ng\Mitsubishi]
And type this into the note: "protect low memory areas"="false"
with or without the " "?
Also, the car has had the year reflashed. I can see the ROM info in ECUFlash, and it says it's a 2013, can't remember off the top of my head. But the car itself is a 2014. I'm guessing the tuner bench flashed it to a different year or something..
Old Sep 17, 2015 | 07:35 PM
kaganader2's Avatar
Registered User
No everything I wrote is to be copied into notepad and saved with the extension .reg
it is to change a reg value so the openport 2.0 wire will overwrite low memory addresses if you want to flash a rom that is not a v2 on a v2 already ecu.
Old Sep 18, 2015 | 07:54 AM
Need an XML
Ok. Where I do I save it? I appreciate the help.
Old Sep 18, 2015 | 10:13 AM
kaganader2's Avatar
Registered User
Save it anywhere and open it up, it will ask you to confirm making a change to the registry key. This gives you permission to overwrite the low mem protected areas of the ecu to flash a v2 (or stock rom back on) on it without benching the ecu to do so.
Old Sep 18, 2015 | 10:35 AM
I'm sorry, what program do I open it with? ECUFlash? I'm a total newb when it comes to this programming level stuff... :/
Old Sep 18, 2015 | 12:03 PM
kaganader2's Avatar
Registered User
Just click to open. it is a windows reg file
Old Sep 18, 2015 | 01:26 PM
Ok, thank you sir.
nabilsx
Sep 20, 2009 09:58 AM
fbikawi
Jun 30, 2009 11:56 AM
mrfred
Mar 27, 2009 03:03 PM
nothere
Jan 28, 2009 11:32 PM
Frederic
Sep 20, 2008 12:08 PM
