No signal from pin 112 (AUDM GSR)
Hi all,
Trying to get my car flex tuned but tuner isn't getting a signal from pin 112. When I installed the pin in to the ecu harness plug, tuner said I placed it in pin 113. Could that cause a short and damage pin 112? He also swapped to a different flex fuel kit (sensor and gauge) and still no signal.
Tuner tapped into the rear O2 for a signal and has been successful however, the readings are off.
No exactly sure how to proceed from here, other than try a new ecu. Unfortunately none available in the time frame to test it.
Car is an AUDM 2011 GSR. Gauge used Innovate ECF-1.
Any help or insight on this issue would very much be appreciated.
Cheers.
Cheers.
Hi all,
Cheers.
Cheers.
WTB[SouthEast]: Wanted Evo X GSR ECU
TheOtherLancer
May 25, 2015 08:19 PM
