4 Bar Definition for 2015 MR
Old Oct 19, 2020 | 07:28 AM
NinjaX's Avatar
Hello all, does anyone have a 4 bar definition information to include on evo10base or tephra for 4 bar?
ECU ID 59590005 or 59590305
Been looking around, however i cant seem to find one that fit my ECU ID.
Best Regards,
NinjaX
Old Oct 23, 2020 | 08:55 AM
crimson red's Avatar
omni4bar definition
Best Regards,
NinjaX
As far as comparing with other definitions, omni4bar definition for 59590004,59590005 is like below:
(Warning: It is not proofed. USE IT AT YOUR OWN RISK.)
Code:
<scaling name="Omni4barpsia16" units="psia" toexpr="x*0.2343" frexpr="x/0.2343" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="Omni4barpsia8" units="psia" toexpr="x*0.2343" frexpr="x/0.2343" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint8" endian="big"/>
<table name="Atmospheric Boost (Omni4bar)" category="Direct Boost (Omni 4 bar)" address="53488" type="1D" scaling="Omni4barpsia16"/>
<table name="Boost Target #1A (High Gear Range) (Omni4bar)" category="Direct Boost (Omni 4 bar)" address="58e9d" type="3D" swapxy="true" scaling="Omni4barpsia8">
<table name="Throttle" address="6301e" type="X Axis" elements="9" scaling="Throttle_Main - Stored Minimum Throttle %"/>
<table name="RPM" address="62f9c" type="Y Axis" elements="18" scaling="RPM"/>
</table>
<table name="Boost Target #1B (High Gear Range) (Omni4bar)" category="Direct Boost (Omni 4 bar)" address="58f47" type="3D" swapxy="true" scaling="Omni4barpsia8">
</table>
<table name="Boost Target #2 (Low Gear Range) (Omni4bar)" category="Direct Boost (Omni 4 bar)" address="57431" type="3D" swapxy="true" scaling="Omni4barpsia8">
</table>
<table name="Target Boost Error Correction (Omni4bar)" category="Direct Boost (Omni 4 bar)" address="58d30" type="2D" scaling="OffsetWGDC">
<table name="Boost Error" address="62fc6" type="Y Axis" elements="17" scaling="Omni4barBoostErrorPsi"/>
</table>
<table name="Omni4bar #1 0x03B6 -> 0x02FF" category="Direct Boost (Omni 4 bar)" address="1a4a2" type="1D" scaling="Hex16"/>
<table name="Omni4bar #2 0x0ED8 -> 0x0BFC" category="Direct Boost (Omni 4 bar)" address="1a4d2" type="1D" scaling="Hex16"/>
<table name="Omni4bar #3 0x0ED8 -> 0x0BFC" category="Direct Boost (Omni 4 bar)" address="1a4e6" type="1D" scaling="Hex16"/>
suprPHREAK
Sep 30, 2009 12:39 PM
Ivan MR
Apr 23, 2006 10:59 AM
alexyim
Feb 15, 2006 06:09 AM
MitsuSkot
Apr 30, 2005 08:01 PM
