Rear Strut Bar or Sway bar?
Subscribe
Apr 27, 2005 | 02:27 PM
I'm just looking for an overview of the difference between the two from RRM, the pros and cons, which is more effective (if they serve the same purpose), ect ect..
Oh, i did do a search, i just couldnt find what i was looking for, please don't flame me.
Thanks for your help!
Reply 0
Apr 27, 2005 | 02:38 PM
id say the sway bar... esp if you get the perches... because its closer to the axel
edit: i have the sway bar and perches and i love them... helps correct the understeer
Reply 0
Apr 27, 2005 | 02:49 PM
The sway bar will give you the most noticable difference. After that, a strut and/or tie bar will make it even better.
Reply 0
Apr 27, 2005 | 02:54 PM
Sway bar + perches, then strut bar, then tie bar. Most effective to least effective. Every bit helps though.
Reply 0
Apr 27, 2005 | 03:46 PM
What exactly do the perches do? Do you need them for the install, or do they simply improve the effectiveness of the sway bar?
Reply 0
Apr 27, 2005 | 03:49 PM
You can use the stock perches to install the RRM/Progress swaybar, but they're not as strong as the aftermarket ones.
Reply 0
Apr 27, 2005 | 04:33 PM
Quote: Sway bar + perches, then strut bar, then tie bar. Most effective to least effective. Every bit helps though.
Sorry sir, its more like
Tein coilovers - sway bar - lower tie bar - rear strut bar
Trust me, i have all of these mods except the rear strut bar
Reply 0
Apr 27, 2005 | 04:38 PM
Get swaybar and perches first!
Reply 0
Apr 27, 2005 | 04:42 PM
Yeah the sway bar is the single most cost effective mod ive done to my car. Playing around with the suspension makes the car SOOOOO much more fun.
Reply 0
Apr 27, 2005 | 04:43 PM
Quote: What exactly do the perches do? Do you need them for the install, or do they simply improve the effectiveness of the sway bar?
the perches that come stock with the car tends to crack or snap when u upgrade to the RRM sway bar. the stronger perches that RRM has will obviously hinder that problem..cause they are stronger!
Reply 0
Apr 27, 2005 | 04:45 PM
Quote: the perches that come stock with the car tends to crack or snap when u upgrade to the RRM sway bar. the stronger perches that RRM has will obviously hinder that problem..cause they are stronger!
There are two people here on the boards who bought them without the perches. They said they still work great.
Reply 0
Apr 27, 2005 | 04:46 PM
Quote: There are two people here on the boards who bought them without the perches. They said they still work great.
well im just saying, there are many cases where the stock perches have cracked..
Reply 0
Apr 27, 2005 | 05:00 PM
Well, I don't have the Teins, so I didn't include those.
Reply 0
Apr 27, 2005 | 05:05 PM
As long as you are going with the sway bar, get the perches!!! I have both, and highly reccomend them!!!
Go here: https://www.evolutionm.net/forums/sh...d.php?t=134649
Reply 0
Apr 27, 2005 | 07:35 PM
I'd think that the stock perches would be just fine unless under GREAT stress...
However when I get my sway bar, I'm going w/ the strong perches!!!
Reply 0
