R35 coils on EVO X
I found some defs for dwell on evoxforums
Code:
Code:
Code:
Code:
Code:
Code:
53040010
Code:
52680015-56290021 <scaling name="DwellTime" units="mSec" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.3" inc="0.064" storagetype="uint8" endian="big"/> <table name="Ignition Coil Dwell Time" category="Timing" address="58555" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="61a2a" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="61a06" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
55570006-55580006 <scaling name="DwellTime" units="mSec" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.3" inc="0.064" storagetype="uint8" endian="big"/> <table name="Ignition Coil Dwell Time" category="Timing" address="585f9" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="61096" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="60f50" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
56890009 <scaling name="DwellTime" units="mSec" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.3" inc="0.064" storagetype="uint8" endian="big"/> <table name="Ignition Coil Dwell Time" category="Timing" address="58605" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="6174e" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="61608" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
58010005 <scaling name="DwellTime" units="mSec" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.3" inc="0.064" storagetype="uint8" endian="big"/> <table name="Ignition Coil Dwell Time" category="Timing" address="5861d" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="61792" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="6164c" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
59540005 <scaling name="DwellTime" units="mSec" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.3" inc="0.064" storagetype="uint8" endian="big"/> <table name="Ignition Coil Dwell Time" category="Timing" address="585b1" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="61726" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="615e0" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
56890013 <table name="Ignition Coil Dwell Time" category="Timing" address="58605" type="3D" swapxy="true" scaling="InjectorLatency"> <table name="Battery Voltage" address="6176a" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="61624" type="Y Axis" elements="15" scaling="RPM"/> </table>
53040010
Code:
<table name="Ignition Coil Dwell Time" category="Timing" address="58559" type="3D" swapxy="true" scaling="DwellTime"> <table name="Battery Voltage" address="6181e" type="X Axis" elements="9" scaling="BatteryVoltage"/> <table name="RPM" address="61360" type="Y Axis" elements="15" scaling="RPM"/> </table>
Code:
I'm using a one off kit SpoolinUp made. The cover plate looks amazing, but didn't fit with the connectors causing it not to be able to be bolted down. Had to use some new hardware and spacers without the cover plate. I'll take a pic later. Sorry for the late update, but have been really busy with other people's cars and no time for mine.
2006GSR
15
Jul 12, 2014 02:44 PM
evodude32
16
May 8, 2013 08:55 PM
browningderek
Apr 21, 2010 12:43 PM
