X Inection Timing or Phasing, Stock ECU
I'm curious if it is possible to adjust the injector timing?
I regularly see a puff of black smoke at the back of my X and can't help but think the injectors are firing too early, in relation to the exhaust valve closing, and I'm blowing a load of fuel out the back for no apparent reason... other than it can't be adjusted on the stock ECU?
It's an SST with an MHI 18k and ID1050x injectors, if that makes any difference.
SinistiR
Aug 24, 2015 03:10 PM
Liqquid
Jan 29, 2011 05:27 AM
