Can't log for the life of me!
Was having some serious problems with my evoscan.. But found out it was just the user...
One thing I cant get is Merlins virtual dyno instructions.. the page just after the program installation where he is setting the columns (pg 111 of 134) in what appears to be a Excel spread sheet, Yah i dont have that nor can I find where it is that I can make those column adjustments. Somebody please help, because I need to graph my afr's.. for fear that I might run lean on my stock fuel pump.. I want to install the walbro 255 and I want to accurately log before and after the installation. |
https://www.evolutionm.net/forums/ev...ut-serial.html
This is how to log your wideband through your rear o2 sensor. |
THANKS, I will do this tonight!!
Now if I can only get evoscan to work right> lol |
Alternatively, you can leave your ECU rear o2 out of it, and log analogue input directly from the OP2.0 "pin 8".
https://www.evolutionm.net/forums/09...0-pin-8-a.html That's dead easy if you have an OBD extension cable. I just patched in through that... Rich |
| All times are GMT -7. The time now is 12:55 PM. |
