EVO X - Difficulty getting in to 2nd gear from 1st.
Old Feb 28, 2008 | 05:14 PM
  #166
BOOSTEZ's Avatar
Originally Posted by dbsears87
It may be mechanical but I guarantee its the fluid. If were actually mechanical the car would do it regardless of car operating temp. Just letting the car idle shouldnt do anything...thats not warming up the tranny fluid. I roll down my driveway and leave it in second, then when I shift its good. I actually just skip 2nd sometimes in my car until its warm if its really cold out. Either way its the cold flow properties of the fluid. Mitsu have never used a fully synthetic tranny fluid so notchiness when cold has always been a problem.
You are correct, but this is NOT the case with the X. It's notchy even when the fluid is warm.
Old Feb 28, 2008 | 06:05 PM
  #167
machron1's Avatar
has anyone tried stomping the clutch pedal to the floor very quickly before shifting? that's how I've always had to shift my VIII. it doesn't like to shift without the clutch almost through the floorboard even though the engagement point is very high. not even after getting the ACT clutch...
Old Feb 28, 2008 | 06:22 PM
  #168
BOOSTEZ's Avatar
I don't have to stomp on my clutch to get it in gear. After the initial warmup, the 1-2 gear shifting is fine.
Perhaps you have an issue?
Old Feb 28, 2008 | 11:03 PM
  #169
STi2EvoX's Avatar
Boostez, the comment that I made was that even though the synchros creating a notchy feeling may be mechanical, that it's most likely a result of trany fluid that isn't well matched to the synchros. The notchiness does go away once the car is warm for the most part, in mine and most others. Only a few people seem to have the notchiness even when the tranny is warm. Who knows, but I've driven my friend's 9 on several occasions, and his feels just as notchy as mine when it's cold. Once the car is warm it shifts fine as long as you shift quickly, which is just how the synchros seem to be designed. Finding a better matched fluid will resolve this, I feel quite certain. This is just my guess, so I am not claiming to know for sure, but judging from how the synchros tend to like hard shifting and have no trouble at high rpms would indicate that the problem is not mechanical but rather just a fluid issue. We will see I guess. Have you driven a X yet? You probably should before you comment further on this issue. I think you'll actually find that once it's warmed up it shifts better than the 8 and 9 did.
Old Feb 28, 2008 | 11:11 PM
  #170
dbsears's Avatar
One thing I also found is that petroleum fluid has worse cold flow properties than a full synthetic. But usually it means that a fluid that shifts stiff when cold is less prone to shearing when very hot (in most cases depending on viscosity.) You can stick in fluid that flows good when cold but when its hot it thins out too much (ie synchromesh). So basically you are giving up a little shifting smoothness to have a more stable fluid at high temps. Which is for anyone who races an evo knows how hot the trans temp fluid gets.
Old Feb 29, 2008 | 05:36 AM
  #171
BOOSTEZ's Avatar
OK. This may be the case. Go on and change the tranny fluid then and see if it's what you suspect.
Old Feb 29, 2008 | 10:30 AM
  #172
machron1's Avatar
if it IS an issue, it can't be that bad. over 111,000 miles and still running strong!
Old Feb 29, 2008 | 10:39 AM
  #173
PDXEvo's Avatar
Damn machron, thats some serious miles!!
I have to say, having driven both cars, the issue in the X doesn't seem as bad, to me at least, as the stock VIII. However, after my tranny rebuild (thanks to Mitsu recall for all Evo VIII's) . I really dont have much issue with the shifting at all to be honest, though its just not super smooth all the time, and I only have the slight resistance going to 3rd gear, and I have no issues with 2nd. It also seems to be less noticeable as the miles pile on, but that could just be me getting used to it.
Old Feb 29, 2008 | 05:49 PM
  #174
tsitalon1's Avatar
on an Evo VIII or IX right? No way did you get that many miles on a X, I don't even think thats possible.
Old Feb 29, 2008 | 06:05 PM
  #175
machron1's Avatar
obviously lol
Old Feb 29, 2008 | 08:39 PM
  #176
BOOSTEZ's Avatar
Sorry to go off topic but do you have a link to this recall? I've never taken my car to the dealer for a rebuild tranny.
Old Mar 10, 2008 | 12:34 PM
  #177
bugnot's Avatar
back on topic, anyone get their issue fixed yet?
Old Mar 10, 2008 | 12:45 PM
  #178
tsitalon1's Avatar
Mine is notchy when cold...not so much when warm.
Shifts like butter at high rpm's and speed shifting.
Old Mar 10, 2008 | 12:49 PM
  #179
YzBrad99's Avatar
Originally Posted by ej257gd
This is the for the new X owners.
Is it difficult to get in to 2nd gear from 1st?
I had my X for a week now with 500 miles.
I been having difficulty with 2nd gear from day 1.
Dealership has told me it is normal.
Thank you.
Junk! Take it BACK TAKE IT BACK !!!!
Old Mar 10, 2008 | 12:50 PM
  #180
EVIL_EVO_VIII's Avatar
Misu tranies are garbage period! My 4th is gringing at high rpms if i shift fast. My clutch is slipping so im not sure if the grinding is due to the worn out clutch
