Installed EVC 6 on Evo X....
Old Mar 16, 2008 | 08:02 PM
TURBODAWG's Avatar
I finally got my Evc 6 from UPS last week. I installed it Saturday and it finally quite raining and took it out to set it up today. Car ran 10.5 psi running on wastegate alone. Got the unit set up to run 22 psi and it falls back to 19 psi by 7k rpm. I havent been able to hook up the RPM and TPS signal yet so that I can fix the boost taper completely. I am waiting to find out a good place to tap in to get the Tach signal. Being that the ECU is under the hood, I would prefer to find a tacho signal inside the car, so I dont have to pull another wire throw the firewall.
Results: The car pulls much much harder now with the added boost in the midrange and up top. It really gets a strong hit about 6000 RPM, when the car smooths out and really hauls. I believe this is the part where the A/F must lean out to a not so "pig rich" ratio and really make some decent power.
I have the warning boost set to 24 psi and set to pull back 1.5 psi of boost pressure if the warning boost pressure is exceeded for more than 500 ms. So it should be safe running and in the higher gears the boost goes slightly higher and this should take care of that and pull it back to approx 22 psi.
With the RPM and TPS hooked up I feel I will be able to achieve 22 psi solid to 7000 RPM. More results to come after I get the RPM hooked up.
Brian
Old Mar 16, 2008 | 08:10 PM
Evo Tengoku's Avatar
ARe you using the easy writer software to map it with RPM?
Old Mar 16, 2008 | 08:29 PM
TURBODAWG's Avatar
You can. But I just do the MAP adjustment on the unit itself. I dont have the Easy Writer software kit. I cant do anything without the RPM hookup, except use it like a normal EBC.
Brian
Old Mar 16, 2008 | 08:32 PM
evokel's Avatar
sweet, tricky ebc, isnt it?
Old Mar 16, 2008 | 08:34 PM
TURBODAWG's Avatar
Not tricky at all once you figure it out completely. It is very simple to use in my opinion, you just have to understand what it can do and how it accomplishes it.
Brian
Old Mar 16, 2008 | 08:39 PM
Mightygnu's Avatar
Very nice, keep us updated!
Old Mar 16, 2008 | 11:33 PM
Chamama's Avatar
I agree. This EBC is very simple to use and setup. With the RPM and TPS tapped, I could customize my boost curve very easily. Without any fuss, I hit 22.5 psi peak holding 21 psi to redline (datalogged through JDMMAP) in my IX.
Very simple to setup.
Old Mar 17, 2008 | 05:59 AM
dcshoeco16's Avatar
I was thinking about using the EVC when I get my evo x, can you post pics of where you mounted it please? thanks
Old Mar 19, 2008 | 06:46 PM
meltdown's Avatar
What's the benifits of being able to customize your boost curve?
With my limited experience I'm thinking you just want the boost to come on fast and hold as much as possible to redline.
Old Mar 19, 2008 | 06:58 PM
TURBODAWG's Avatar
With set duty cycle EBC, or MBC, the boost will drop in the upper RPMs due to increase back pressure in the exhaust which helps the pressue in the wastegate actuator open the wastegate. If you customize the EBC to compensate for the increasing exhaust back pressure, you can maintain the same boost pressure to redline (up to the maximum physical flow characteristics of the turbo). All MBC and EBC (without this feature) will taper boost up top with the stock based turbos.
Brian
Old Mar 19, 2008 | 07:35 PM
meltdown's Avatar
Gotcha.
I just always assumed that all EBC's would electronically adjust their internal solenoid to maintain the boost to what you set it to.
Old Mar 19, 2008 | 07:46 PM
TURBODAWG's Avatar
No. It would have to be a "closed loop" EBC . There was a few back in the day, but they have gone to the "wayside". All EBC's on the market that are commonly used are fixed duty cycle boost controllers. You set the boost controller to hit the boost you want, and set it there. That sets a certain duty cycle or step (for stepper motor type), and the controller maintains that setting. When the air temp changes dramatically from when the unit was originally setup, the boost will raise (cooler) or lower (warmer). But in this case we are solely talking about it dynamic changes in exhaust backpressure with RPM that causes boost taper. The EBC is oblivious to this boost taper and does nothing to try to correct it.
Brian
Old Mar 20, 2008 | 06:21 AM
DC_TypeR's Avatar
I didn't have a chance to grab an EVC6
we used the AEM Tru Boost gauge, have the boost set to 23psi and it tapers down to 19.2-19.5.
Mike W at RRE are getting prices on the EVC6 for me, we are going to tap the tach and tps (which is already tapped right now, I think) in th engine bay.
i'll be hitting you up soon.
-Chris
Old Mar 20, 2008 | 06:57 AM
We tapped RPM and TPS on my IX. Im using "fun" 5 to show RPM and TPS. I have never mapped the boost by RPM so should I turn "fun" to 1 (off)?
Old Mar 20, 2008 | 09:14 AM
Chamama's Avatar
With the "fun" in 'off' position, my boost was tapering to 19 psi by redline. With RPM+TPS, I could hold 21 easily. Probably more if I wanted.
I defined my RPM points to 5600, 6000, 6400,6800,7200 and TPS 0,25,50,90,100.
I only corrected TPS 90, 100 and related RPM grid points. This is how I did my setup. You have to do trial and error for your case. Of course I could datalog boost, so I knew what grid points to correct for MY car.
Sorry for going off-topic.
