AMS 373whp & 388whp -EVO X
i did contact with mike, and this is what i got from him:
quote:
"LOL well we got 37psi out of the stock turbo. The sucker won’t go anymore thought.
And if you look at the video I made me daily driving. You can see how much boost it makes on daily base. That’s 93 straight.
http://titsup-racing.com/video/evo/2...ng_to_work.wmv
From that video you can see how much boost I ran all day and all night.
Hope this helps you out.
And I think the new motors should be able to take more then the 4g63. And yes I can be wrong lol. Someone has to just try and see what they can get out of it."
a reason i asked him because i wasn't 100% sure. But i didn't know he did run on that high PSI . with no C16 mix
We were able to get peaks of 36 to 37 psi on the Evo 8 and 9 turbos with the boost controllers turned wide open. This turbo seems to be similiar. We didnt do such peak spikes on anything less than 100 octane fuel though. Running at that high of a peak will show you what the turbo has in it on the top end though. If it peaks at 37 psi, what it runs at 7500 RPM is what the turbo is capable of.
Brian
Brian
I'm sure the straight pump gas numbers will come soon too.
It is amazing how this new engine with little mods will serve the majority of evo owners, and put shame on other manufacturers face...
but the gain % is a same so it is a very good gain, i would say awesome! Also i believe in AMS. They proved them self already, they dont need dreamed up numbers. Would hurt them more then help them.
Good numbers.. but thats some pretty high boost. Can we expect more power at the same boost when more tuning options are available? Sorry I'm a bit ignorant when it comes to this kinda stuff. All I can do is compare it to the 4g63 at similar boost levels.
