Ultimate Racing Test & Downpipe Review
Old May 4, 2008 | 01:38 AM
Talon_66's Avatar
Parts arrived quickly from Darryl @ Ultimate Racing, were packaged nicely.
I went with the resonated testpipe and downpipe w/ wideband bung.
Welds are awesome, the craftsmanship looks top notch. And also they are much lighter then the stock pieces.
Pre-install (2 weeks ago) I installed my ETS Dual Exhaust. It is loud, deep and mean.
Now that it is mated with the 3" downpipe and resonated test pipe it is much deeper, and isn't quite as loud on the high end. The rumble of the exhaust can be felt from the driver seat.
If you look at the UR testpipe you will notice an angled O2 bung, there solution to a CEL. So far, I have not gotten a CEL.
Installation
To remove the Downpipe, you must remove the stock cross brace under the car, two 12mm bolts, and two 14mm bolts.
Now getting to the spring bolts of the downpipe are a nightmare!
I used a half inch rachet, with a swivel, 4" extender and 8" extender. The bolt on the driverside was quite easy, you can see it and can aim the rachet in and get to it. The passenger side proved to be quite a pain. I found it helpful to have an extra set of hands working above holding the socket in place.
Removal of the 02 sensors on the stock cat and downpipe required quite a bit of elbow grease to get out.
Testpipe was straight forward.
Parts cost $458 shipped, and are well worth the price
Old May 4, 2008 | 06:33 AM
Noize's Avatar
EvoM Administrator
I have these waiting to go in. I took one look at that driver's side spring DP bolt and stopped the whole thing. I'm waiting until I am at the shop with a lift.
NIGHTMARE. What the heck was Mitusbishi thinking?
I can't wait to get mine on. I got the same stuff, but with the mini muffler in the test pipe instead of the resonated one.
I should have tuned dyno numbers on them this coming weekend.
Old May 4, 2008 | 06:47 AM
evostang's Avatar
When you removed the factory downpipe, do the springs and bolts stay retained in the downpipe or do they fall out once the bolts are removed? Thanks.
Old May 4, 2008 | 10:51 AM
Tunerhead's Avatar
Nice.....I will have to check on getting one of these.
Old May 4, 2008 | 01:25 PM
Noize's Avatar
EvoM Administrator
They fall out.
Old May 4, 2008 | 04:27 PM
Talon_66's Avatar
Originally Posted by Noize
They fall out.
x2
Old May 4, 2008 | 04:50 PM
holyfrickster's Avatar
Nice review, I like the way they have a variety of test pipes available. Glad to see that you like it.
Old May 4, 2008 | 04:59 PM
finallyaevowner's Avatar
thx for the review i have mine in the trunk and hope to be able to put them on in a few days and i agree they look like they are well built and welded
Old May 4, 2008 | 05:04 PM
xbox4414's Avatar
Wow that is a lot of welds for one single piece...not sure how I feel about that...
Old May 4, 2008 | 08:21 PM
SilverEvoX's Avatar
Very nice ordered the straight test pipe from Ultimate Racing on Friday morning. Looking forward to it coming it and got the wide band bung option. Do you have any sound clips of it all bolted up now with the new downpipe/test pipe? Thanks ~Trent
Old May 4, 2008 | 09:29 PM
Noize's Avatar
EvoM Administrator
I got mine finished tonight. Its really not that hard with a swivel at all. It looks more intimidating than it actually is. I ended up using a super long extension and a medium sized one for the win.
So now I have a full Ultimate Racing turbo-back with mini muffler in the test pipe section. The car is a bit louder under WOT, but the mini muffler helps deaden the sound a lot. Butt dyno doesn't feel a gain, since the tune was optimized for a cat-back. Going to remap this coming weekend.
Old May 4, 2008 | 11:55 PM
MooseX's Avatar
Thanks Noize for that tip . I went with the UR metal catted test pipe (a bit more than the ceramic one but better flow) and their Downpipe. I have the test pipe and now waiting for the DP to get to the west coast
UR ftw. good welds and a price you can't beat
Old May 5, 2008 | 09:21 AM
Ultimate Racing's Avatar
Nice review. Thanks for the positive words
Darryl
www.ultimate-racing.com
Old May 5, 2008 | 12:10 PM
DrasticK's Avatar
I also got the downpipe/testpipe/catback, and i must say, Ultimate Racing is the best
Installation wasn't a problem, the welds are nice, the performance is incredible, and it sounds wicked. Very satisfied, would recomend.
Old May 6, 2008 | 01:23 AM
Flooby's Avatar
was wondering if the test pipe throws the CEL because i think im going to buy the test pipe and down pipe but am worried about it throwing the light...
