*PRODUCT RELEASE* Buschur Racing Spec Evo X JE Pistons
*BUSCHUR RACING EVO X PRODUCT RELEASE*
It took a little longer than expected to get these finished but they are finally done and instock!
What you will be purchasing is NOT your standard off the shelf JE Piston.
Teaming up with JE as we did on our other Evo pistons it has allowed us to work closely in the development of this product and get everything done to our specifications. These are ONLY available through Buschur Racing or your local Buschur Racing authorized parts distributor.
Compression Ratio: Stock (9.0:1)
Available in: Standard Bore or .20 over bore.
What you will receive with each kit is:
Pins
Retainers
JE Sure Seal Piston Rings
Complete set of 4 BR Spec JE pistons
Because these engines are so new, you would be able to use the standard bore as a direct drop in forged piston upgrade.
These pistons have also been J&E tough skirt coated. This is a special process that helps with the oiling and prevents excess wear.
Available here at the shop or online: BR Evo X JE Pistons
Pins
Retainers
It looks good. So this piston has a better quality than stock? For all of guys who doesn't have great understanding in engine building, do you mind explaining how this piston is better than stock ones? More HP? Longevity?
This maybe a dumb question, but in my experience with EVOs, usually it's the rods that are the weakest link in the engine. Since you guys made the pistons first, does that mean pistons are the weakest link in the EVO X?
