Artisan 3" Carbon Ti Single Exhaust
Old Oct 28, 2008 | 06:33 PM
  #91
ikuto's Avatar
Request
Does anyone have a video clip of this exhaust inside the car while driving?
Thanks.
Old Oct 28, 2008 | 07:01 PM
  #92
stikllr13's Avatar
Originally Posted by jayevo23
did you get pulled over with just the cat in? if i did go single iwas going to go with this exhaust or ams. if i went with this exhaust i prolly end up selling the test pipe
i got pulled over when i was running cat-less. It was pretty loud but a good loud after i had the cat put in i think its at the perfect volume
Old Nov 3, 2008 | 08:22 AM
  #93
Kadavr's Avatar
Originally Posted by Geo@SpeedClinic
They are goign to come out with a dual setup as well within the next few weeks.
Any updates regarding the dual setup?
Old Nov 3, 2008 | 12:33 PM
  #94
Mr. Furley's Avatar
Can the stock heat shielding be removed? Everyone seems to leave it on after exhaust.
Old Nov 3, 2008 | 02:20 PM
  #95
Robevo RS's Avatar
why would you remove any heat shield if its not necessary?
They usually weights nothing and they are there for a reason. Not to mention when you going aftermarket , that is usually thicker piping so it is even closer to the body where is the heat shield is placed for a reason...
Old Nov 3, 2008 | 06:39 PM
  #96
Mr. Furley's Avatar
If it's not necessary, why keep it?
Old Nov 3, 2008 | 06:44 PM
  #97
macPSU's Avatar
I think he's trying to say that it's not necessary to remove the heat shield. It's there for a reason, what positives are there to removing it? Just curious as to why you would want to take it off.
Old Nov 3, 2008 | 06:56 PM
  #98
switchblade906's Avatar
looks sweet i might want to change my ETS dual for something like this
Old Nov 4, 2008 | 12:32 PM
  #99
Robevo RS's Avatar
thanks
Old Nov 4, 2008 | 07:44 PM
  #100
Mr. Furley's Avatar
thanks
I understood what he was saying. But with a single aftermarket exhaust it looks to serve no purpose and is just wasted weight. Even if it weighs .4 lbs.
Old Nov 5, 2008 | 01:00 PM
  #101
Robevo RS's Avatar
there is the AYC and many rubber lines, etc protected by the heat shield if i remember right. I would not remove that heat shield.
and it probably weight less then 2lb. but is your car your call.
Old Nov 5, 2008 | 04:01 PM
  #102
ejay732's Avatar
nice!!! so when is the dual gunna be ready for me to purchase??
Old Nov 6, 2008 | 07:07 AM
  #103
Geo@SpeedClinic's Avatar
I just emailed muy guys at Artisan. I will post here when I get a reply. I know they are showing their cars/products off at SEMA right now so it might be a little bit but I will get you a answer.
Old Nov 11, 2008 | 11:37 AM
  #104
PRORICAN's Avatar
Im picking mine up today! Thanks Geo!
Old Nov 12, 2008 | 08:38 AM
  #105
ScorpionT's Avatar
Pretty nice exhaust I must say.
