biggest exhaust cork?
Old Aug 1, 2008 | 01:20 PM
hayasa's Avatar
Which part of the X's exhaust is the most restrictive? For instance, replacing just the axle-back would give you how much hp? Just Midpipe? Just Downpipe/O2 pipe? Anyone done any clear experimenting on this (keeping everything stock except for the piece being tested)?
Old Aug 1, 2008 | 02:18 PM
SilverEvoX's Avatar
I'm pretty sure it's the 02 housing section. Secondly I'd say the test pipe if for no other reason because it helped spool up tremendously
Old Aug 1, 2008 | 02:36 PM
evostang's Avatar
I think it's a toss up between the muffler and cat.
I measured the factory system at 9.5 psi backpressure in the down pipe, like 8 inches in front of the cat.
Nobody has done pressure measurements of each component, and I suspect I'm the only one who has done the whole system. However, there are lots of dyno graphs from shops changing just one part vs the other.
Old Aug 1, 2008 | 03:25 PM
Rguy's Avatar
The stock muffler for sure. It's really badly designed with respect to flow.
Old Aug 2, 2008 | 07:03 AM
EvilEvo9MR's Avatar
^^+1 believe it or not The stock muffler is usually the most restrictive part in an exhaust system
Old Aug 4, 2008 | 03:39 PM
XxXtremeEvoX's Avatar
pretty much everyone got it. O2 housing, cat, and muffler.
Old Aug 4, 2008 | 04:52 PM
Rguy's Avatar
Check out the stock muffler and how many turns and chambers the exhaust has to go through.
PRYDzzz
Apr 27, 2015 11:42 AM
Jade daddy
23
Nov 11, 2014 04:25 AM
Tommygun916
Aug 10, 2014 03:04 PM
khmerguyx
Apr 10, 2014 09:04 PM
Osborn
Oct 17, 2012 03:55 PM
