wastegate?
Old Aug 6, 2008 | 05:34 PM
04gsr's Avatar
how much? if possible could you post the boost graph
Old Aug 7, 2008 | 07:34 PM
4myX's Avatar
quick question, If my MBC was by-passed how much boost would the wastegate hold before it opened? Thanks
Old Aug 8, 2008 | 08:07 AM
evostang's Avatar
I measured that the wastegate cracked open at 14 psi without adjusting the OEM wastegate actuator. With the actuator clevis adjusted in 3.5 turns, the wastegate opened around 16 psi.
Old Aug 11, 2008 | 09:28 PM
dkstas's Avatar
Originally Posted by xtremeboost
The actuator will indeed help in holding boost better at higher boost levels all teh way till redline . We have ran 30lbs on this actuator many times .
I just installed my Forge actuator, and I have my ebc turned all the way down and my boost is spiking to 28 psi and holding at 26-27 psi. Is this normal?
Old Aug 11, 2008 | 10:54 PM
xtremeboost's Avatar
If your you have your EBC tuned down and its spiking at 28lbs then your pre-load is set too high . Also did you install the lines to the EBC's actuator box set-up for internal wastegate ? Who tuned your car ?
Old Aug 11, 2008 | 10:58 PM
dkstas's Avatar
Well the only thing I did was install actuator then turned my ebc all the way down. After I saw it spike to 28 psi, I adjusted the rod out and now its spikes to 22 psi, but drops off to 16-17 psi like the stock one did. Is there a sweet spot on it?
Old Aug 11, 2008 | 11:01 PM
which EBC you have and how is it set-up ?
Old Aug 11, 2008 | 11:07 PM
dkstas's Avatar
^I have the gizzmo msbc. My boost controller works fine, I don't really know how to explain how it hooks up. I just turned the boost controller down just to see what the wastegate would hold on its own. I figured if it would spike to 22 psi, it would hold 22 psi to redline. Right now if I use the boost controller and adjust the duty cycle it can hold 24 psi, dropping 1-3 psi. Just wondering how you guys made it hold 30 psi till red line? Thanks.
Old Aug 11, 2008 | 11:17 PM
OK , so you start off with the EBC tuned down thus running off the per-load of the wastegate and that goes to lets say 22lbs . So what you're saying is that the EBC is not able to bring up the boost to ?? We actually spiked about 34 and held 30 with the same unit . You should not have any issues getting your boost set . How many times has your car gone into limp mode , just wondering .
Old Aug 11, 2008 | 11:22 PM
dkstas's Avatar
Never. Weird huh, nor boost cut? Well I can set the boost, I just thought the actuator would kill the taper at like 24 psi. Will adjusting the pre-load fix this?
Old Aug 11, 2008 | 11:25 PM
hummm , no boost cut or limp mode - strange ... Try taking the per-load up a bit at a time unit you stabilize the boost where you want it .
Old Aug 11, 2008 | 11:28 PM
dkstas's Avatar
Will do. Thanks for your help!
Old Aug 11, 2008 | 11:34 PM
if you run into any other issue feel free to PM your question .
Old Aug 12, 2008 | 12:56 AM
benklepacki's Avatar
I am a bit confused. What is the benefit of the Forge actuator over adjusting the stock one?
Old Aug 12, 2008 | 05:37 AM
dkstas's Avatar
^From what I can tell it has more adjustability.
