MR bounced off rev limiter in Sport auto mode
Old Aug 20, 2008 | 09:50 AM
ksattic's Avatar
This morning, my MR bounced off the rev limiter in Sport auto mode.
Some details: I was doing 15mph in sport mode (auto) and the car was in D2 at the time. I gave WOT and the transmission shifted to D1. The car accelerated and I watched the revs as they approached 7k. At just before 7.5k (approx), I felt the rev limiter kick in and the car decelerated rapidly, before it finally shifted into D2.
I did not at any point touch the shifters. The car was in D (auto).
My car has 2k miles and has the WORKS drop in filter, and that's all.
Old Aug 20, 2008 | 10:02 AM
DirectorSe7en's Avatar
Mine has done that a few times and I've modded quite a bit.
It seems that the car can't select the next gear quickly enough when accelerating that quickly, so it just revs all the way up until it can switch.
.....then again, that's just what it "seems" like to me. Could be anything.
Old Aug 20, 2008 | 10:14 AM
ksattic's Avatar
OK, that's what I was fearing. I do notice a slight increase in power with the WORKS drop in, even though I don't have a flash, and it seemed as if the transmission changed a little too late before the rev limiter cut in.
I was going to change the exhaust and get a tune but now I am thinking I will wait. Bouncing off the rev limited obviously slows you down a lot. I am thinking this means that our cars will not take kindly to mods when used in Sport mode unless the transmission can be reprogrammed to avoid this kind of problem.
Have you seen the same problem in S-Sport mode?
Old Aug 20, 2008 | 10:26 AM
I think you'll be safe with the Tune. I'm at 292whp/294wtq and drive pretty hard everyday and have not (knock on wood) had any problems other than sometimes bouncing off the Rev limiter.
Here are my Mods. There is more detail if you click my sig.
AMS FMIC
AMS UICP
ETS LICP
ETS Dual Exhaust
MBC @ 22 psi
ECUtek Tune
NRG Tech Test Pipe
AEM Intake
Old Aug 20, 2008 | 10:30 AM
Evo Tengoku's Avatar
D7, has it only happened to you while in D1 gear?
Old Aug 20, 2008 | 10:44 AM
NO_WAY's Avatar
Solution! sell the mr and buy a gsr!
Old Aug 20, 2008 | 10:47 AM
Nope, happened in D1 once, and 2 or 3 times in D3.
It's usually when I'm driving around in Sport mode then suddenly floor it.
Old Aug 20, 2008 | 10:56 AM
xPRimNT's Avatar
I know it's been asked before, but have you ever had this in S-Sport mode?
I'm shocked that the TCU lets you hit limiter in sport mode... I did not see that one coming...
Old Aug 20, 2008 | 11:07 AM
goofygrin's Avatar
Then you get to bounce off the rev limiter all the time!
(or hold it right there if you need to at the track)
Old Aug 20, 2008 | 04:36 PM
gunzo's Avatar
I bounce off 1st and 2nd on a totally stock car .. it's normal ..
you'll find that even in manual .. you need anticipation to shift from 1st to 2nd .. worse if you mod ..
Old Aug 20, 2008 | 07:17 PM
verkion's Avatar
Interestingly enough, this will ONLY happen if you are in D2 or D3 and it downshifts and then needs to upshift again. This does NOT happen from a stop. At least, it has never happened to me from a stop...
verkion
Old Aug 20, 2008 | 09:44 PM
DVDee's Avatar
Use s-sport.
Old Aug 20, 2008 | 11:02 PM
Gexxer's Avatar
it still a brand new system. you cant expect it to preform perfectly... what you should be doing is emailing mitsubishi so they can note it and try to reproduce what you did.. this will let them fix it, either in programming or rapid evolution of the sst
Old Aug 21, 2008 | 04:44 AM
gunzo's Avatar
verkion
Nah .. it happened to me on stand still also ..
Old Aug 21, 2008 | 08:49 AM
ksattic's Avatar
It was performing perfectly before I added the air filter, so I'm not sure how Mitsu would react if I told them all the information - they'd probably void the warranty. I believe the transmission *may* be preset for the car in its stock form.
