MR bounced off rev limiter in Sport auto mode
Old Aug 21, 2008 | 02:36 PM
POMPOUS_JACKASS's Avatar
Originally Posted by NO_WAY
Solution! sell the mr and buy a gsr!
I'll totally swap my GSR with someone wanting to get rid of their MR!
Old Aug 21, 2008 | 03:00 PM
lowkey's Avatar
Registered User
Originally Posted by gunzo
I bounce off 1st and 2nd on a totally stock car .. it's normal ..
you'll find that even in manual .. you need anticipation to shift from 1st to 2nd .. worse if you mod ..
It's normal that instead of shifting the car hits the rev limiter while in auto mode?
Old Aug 21, 2008 | 06:01 PM
verkion's Avatar
Hrm...I'll try it after I put the drop-in HKS filter and let you guys know if I have that problem since I don't seem to have this problem when it is rowing through the gears one way (i.e. shifting up from a standstill), but some others do.
verkion
Old Aug 24, 2008 | 01:04 PM
sales@fastcraft's Avatar
i have a K&N filter and mine is fine.
If you slow down slowly it stays in a high gear to long saving gas, then floor it sometimes it gets caught out it's suddenly has to snap down three gears then go up one or two and the gear selector cant be on two odd or two even gears at once. Thats my thoughts anyway.
Old Oct 17, 2008 | 10:44 AM
karlr's Avatar
mine has been doing this also.. any updates on a fix.. im worried i may do damage to my motor it has happened 2 times in the last week but only in sport mode. which i thought is supposed to do all the work if you wanted it to.
it has only happened from a stand still from 1st to 2nd gear also
Old Oct 17, 2008 | 11:28 AM
ksattic's Avatar
karlr: is your MR stock? Even if you have changed the air filter, let us know.
BTW, the rev limiter is designed to prevent damage to your engine. It cuts the fuel long before the engine revs high enough to cause damage.
Old Oct 17, 2008 | 11:37 AM
bvliz's Avatar
i have hit the limiter 2 times while stock,i was beating on the car getting the trans hot.i wonder if the trans is getting alittle to hot and the clutch slips a tad.
Old Oct 17, 2008 | 12:04 PM
karlr's Avatar
100% bone stock. car is only 3 weeks old 1100 miles on it. it did it once when a week old and a second time yesterday. and I have only used sport mode 2 times and both times it did it im afraid to try a 3rd time. I talked to the dealer they are clueless and didnt even know the car had a rev limiter lol...
Old Oct 20, 2008 | 08:53 AM
ksattic's Avatar
OK, thanks for the info.
Mine did it again this weekend, standard situation - was cruising in 2nd and then floored it. Car revved over 7.5k before rev limiter cut in, and car didn't shift for what I would call a significant time. I still only have the WORKS drop in air filter.
I would say there is a clear problem/bug if someone with a stock vehicle (above) is having this problem.
Old Apr 27, 2009 | 10:29 PM
alphawav's Avatar
any updates on this?
I'm very curious what happened re: hitting the rev limiter in auto mode.
Old Apr 27, 2009 | 11:37 PM
verkion's Avatar
I don't know if "learning" is the correct term for this, but after flashing, I WILL hit rev limited in 1st and 2nd. That only happens once or twice and then it goes away. The TCU I guess figures out that it has to shift slightly earlier. In fact, if I have a new rom that I like and will use for Daily Driving, I make it a point to do a WOT in 1st and 2nd just so that it CAN hit the rev limiter and figure out that it needs to shift a little earlier. :-P
verkion
xBoostx
Oct 7, 2016 01:47 AM
Burkeyro
Mitsubishi TC-SST Discussion
32
Sep 16, 2010 05:44 PM
tonydig11
10
Jul 8, 2010 08:46 AM
crewdawg130
Jul 9, 2009 07:01 PM
dklau33
39
Nov 26, 2007 05:20 PM
