NEW! Cobb Tuning EVO X short Shifter!
Old Sep 9, 2008 | 08:39 AM
RallySport Direct's Avatar
Silver Sponsor
Constructed from black zinc plated steel and billet aluminum anodized in Cobb blue. Throw is independently adjusted from knob height. Throw is reduced by as much as 15% over stock.
Independent knob height adjustment from throw adjustment.
Billet Aluminum body (anodized Cobb blue)
Black zinc plated upper and lower pivot ball
Allows for use with OEM knob
Stainless Steel socket head screws
Up to 15% shorter throw
MSRP 165.00
What you guys think?
Old Sep 9, 2008 | 08:53 AM
Dyno4mance's Avatar
Sounds like what I have been looking for, but one question:
Will the boot fit over the aluminum knob height adjuster??
Old Sep 9, 2008 | 09:08 AM
jd888jd's Avatar
i want to see it installed..
Silver Sponsor
Yes it will.
All Cobb items are designed to work with OEM parts.
Old Sep 9, 2008 | 09:09 AM
Silver Sponsor
Ill email Cobb right now and try to get images asap!
Old Sep 9, 2008 | 09:29 AM
JoeyM3's Avatar
hmmmm i wonder how this will compare to my works ss
Old Sep 9, 2008 | 10:36 AM
Hiboost's Avatar
How much shorter in inches or mm is 15% over stock anyways, just curious.
Old Sep 9, 2008 | 10:40 AM
Silver Sponsor
The 15% shorter throw, is the length difference between you putting it from one gear into another. High on it can be adjusted separately from the throw. So you can have the shifter sit almost at stock height, or have it sit very low.
Old Sep 9, 2008 | 11:16 AM
Massappeal's Avatar
very interested in this item. musst see installed pics!
Old Sep 9, 2008 | 11:18 AM
Silver Sponsor
Old Sep 9, 2008 | 11:26 AM
JoeyM3's Avatar
can you ask them for pics installed, with the boot at the lowest setting?
Old Sep 9, 2008 | 02:55 PM
Silver Sponsor
Both are in Neutral Position
Highest Position
Lowest Position
Old Sep 9, 2008 | 03:53 PM
EvilEvo9MR's Avatar
The works reduces throw by 25% and is a little cheaper...159
The cobb reduces throw by 15% and is a little more expensive see price above^^ Then again the cobb has the adjustablity over the works choices choices.... I would probably go with the works just because I am one of those people that will always be messing with adjustments if I got em
Old Sep 9, 2008 | 04:24 PM
Joe's Evo X's Avatar
Nice i think i would go with this over works cuz i dont want to short of a shifter. 15% shoulds good to me and you can adjust it. awesome.
Old Sep 9, 2008 | 06:28 PM
DVDee's Avatar
This part looks good. I wonder which would feel better though this or the Works part.
