EVO X with Cosworth Cams (Before and After Dyno Graph inside)
Old Sep 26, 2008 | 12:54 AM
05-EVO-GSR's Avatar
Just ran the cams on a already ECUTek tuned EVOX. The car has intake, full exhaust, piping, biggee i/c. Nice MBC. Stock fuel system. One of the strongest cars I have dynoed and tuned so far.
This is before and after. Before tuned and running good. After is cas only, no other mode and not re-tuned. Same boost before and after.
Then did a little tuning. Added a degree of ignition advance between 3500 and 6000 since there was no knock or timing pull. Played with MIVEC a little. Overall about three tweaks as time allowed. ECUTeK takes a long tome to upload changes. Boost is untouched.
So, overall gains with the cams installed and some touchup tuning.
Fun stuff. These are an early release pair. Production ones are still a few weeks away.
Mike W
Old Sep 26, 2008 | 01:44 AM
Jon H's Avatar
Good stuff. Should make Evo X owners happy.
Old Sep 26, 2008 | 06:08 AM
Hiboost's Avatar
Seems slightly odd that the cams make the most gains in the 5500-6500 range but 40 WHP is a ton from cams! 30 AWTQ are nice gains too though so they look better in every way. I'm wondering if these would get me to the 113-114mph trap speed range even on the stock turbo. Definitely worth looking at for when I upgrade turbos/fuel in the spring though!
How was the idle and drivability? Did you need upgraded valve springs?
Old Sep 26, 2008 | 06:46 AM
robb86's Avatar
didn't even know these were available - any vendors have em?
are these 272's?
Old Sep 26, 2008 | 07:47 AM
Mightygnu's Avatar
are these 272's?
They are a early release pair, not quite available to the public. I know who's car this is
Old Sep 26, 2008 | 09:34 AM
DC_TypeR's Avatar
And whose car would it be young man? LOL
Cossie isn't going to release these until October.
VERY VERY Nice numbers from these cams.
-Chris
Old Sep 26, 2008 | 09:53 AM
Mightygnu's Avatar
I won't say here, but you have a PM Chris.
Old Sep 26, 2008 | 10:21 AM
Massappeal's Avatar
i see 400whp on stock turbo in the future!
Im curious to how reliable these cams will be cause the power is Def. worth it!!!
Old Sep 26, 2008 | 10:32 AM
Guru's Avatar
I'll definately say it again. The 4B11 cylinder head is AWESOME compared to the 4G63 head. Even with boost dropping like a rock it still makes peak power at 6600 RPM or so. I wouldn't be surprised to see 400 WHP on the stock turbo when more parts become available for the car (particularly intake manifold). So glad I bought one. Are you guys running stock injectors? Larger injectors? What IDC are you seeing?
Old Sep 26, 2008 | 01:25 PM
Jason's Avatar
Wow looks great guys, i have been patiently waiting to see what cams would do on the X
Old Sep 26, 2008 | 06:16 PM
Clark_Kent's Avatar
Thank you for sharing. I have been anxiously waiting for data on camshafts for the X as of late. Great gains! Very nice.
Old Sep 26, 2008 | 06:46 PM
Mightygnu's Avatar
This car is a beast!
Old Sep 27, 2008 | 10:09 AM
BigmikeOC's Avatar
Nice power increase from cams.
I've never done cams on a car with variable valve timing, is this a pain in the **** to install or is it pretty straight-forward?
Old Sep 27, 2008 | 11:40 AM
Papi4baby's Avatar
When is this going to be available!!!
What else will updating to handle the cams!!!
Will testing be done on a bone stock X to see the regular results?
Thank you.
Old Sep 27, 2008 | 12:48 PM
DC_TypeR's Avatar
Papi4baby,
I don't think people are going to be dropping in cams on a BONE STOCK Evo Period... it's not your typical "first mod"
Cams are going to force more air in and out... and without the proper mods, imo you wont see "great" benefits.
You'll atleast need a drop in filter/ full exhaust and a tune to take advantage.
I think those numbers are what 85-90% of Evo X owners can expect to gain. Although these are the test sets from Cossie, The real sets should be exactly the same. If I can remember correctly, these are the 272's
BigMikeOC
I think these cams will be a bit more difficult to Install/Remove..so I have heard haha. It's not the MIVEC either, it's the fact that it's a timing chain, instead of Timing Belt.
Guru
Those numbers are w/ the stock injectors, stock fuel pump, PER MIKE W of RRE
Hope that answers some of your questions.
-Chris
