AMS's EVO X makes 480whp on pump gas and prototype turbo kit
Old Oct 7, 2008 | 12:49 PM
  #31
PwrEvo's Avatar
Nice job AMS!
Old Oct 7, 2008 | 01:07 PM
  #32
06SilverEvoSE's Avatar
good stuff...cant wait to see some times
Old Oct 7, 2008 | 09:41 PM
  #33
dankaristo's Avatar
Originally Posted by Chris@AMS
I don't think you understand how horsepower and torque work, or are related to each other.
Fuel pressure = torque? Please don't mislead people who don't know any better.
I promise you that tuning is not the reason why it doesn't make as much torque as you think it should.
Do you understand that horsepower and torque are equations of each other?
Please dont read between the lines and make me sound like I am handicap.
Fix your shortcomings and see where it leaves you.
(Torque x Engine speed) / 5,252 = Horsepower
..i dont think i like ams anymore lol
Old Oct 7, 2008 | 09:55 PM
  #34
VincentX's Avatar
You are not going to get torque equal to horsepower with that turbo and 2.0 liters.
Old Oct 7, 2008 | 10:37 PM
  #35
spdracerut's Avatar
If you want 500 lb-ft of torque, that'll probably require in the ballpark of 35psi-40psi of boost. You better damn well be making more than 500hp if you're pushing that much boost.
If you're making 500/500, basically the turbo is choking on the top end.
Old Oct 8, 2008 | 06:51 AM
  #36
AutoMotoSports's Avatar
Nobody is saying you are "handicap" I think you are reading into things a little much and or being a bit defensive.
Chris is right in his post....I think you are having a hard time understanding how Horsepower and Torque relate to each other. Horsepower is a function of torgue. Turning up the fuel pressure on this car is not going to make any improvements. The fueling issue we are having is a case of volume not pressure, we can crank the living daylights out of the fuel pressure but if the pump cannot keep up the supply it all means nothing. We need to put a bigger pump in the car.
As far as making a 500/500 car...Sure you can get a 500ft lb torque spike but it will result from a massive spike in HP sourcing from a massive spike in boost. Horsepower is a function of torque....you can't change one without changing the other....which you can see from your simple equation that you posted up.
I don't understand why you are asking him to "fix Your shortcomings" when you have not clearly explained yourself. Quite frankly we are reasonable people but that statement comes off as a bit insulting and disrespectful.
We are not here to belittle or talk down to anyone. We are here as a company of course to promote our product. We also are here to educate. If you would like to start an open, respectful conversation on the topic we will be more than happy to accommodate you. There is nothing we love more then a well educated customer. Our products are designed just for them. It is their critique that pushes us to be even better at what we do.
Eric
Old Oct 8, 2008 | 04:46 PM
  #37
Weezheat's Avatar
I think some people saw the graph too quickly, looked @ numbers and said "crap"
Yes, 343TQ is not something astronomical, let's not kid ourselves. But most graphs will show a beel shaped curve, with a peak in TQ and then some decline.
This trubo, thus far, is holding 340TQ from 4.7 to 7.5k RPM. That is.. something.
Peak #s dont win races, the curve does, and this curve holds the power all the way.
Old Oct 8, 2008 | 07:34 PM
  #38
Hiboost's Avatar
The waste gate spring we are running is a bit much for the setup currently. The boost starts off at 21 psi and is at about 26 psi by the time I let out of the throttle. Also, at about 7700 rpms, the car is excessively lean because of the stock fuel pump dropping pressure (12.5:1).
Because of the boost creep this thing makes power like a honda. However, the VE on this motor is very good to begin with so I am anxious to see what a 35R will do on this kit when the boost is held constant.
I would imagine once the fuel is safe on the top end that changing the boost set point to 26-28 psi will dramatically boost the peak torque numbers down low to around 400 ft lbs figuring about 10 ft lbs per 1 psi or so as an estimate, maybe more!
Originally Posted by Thegame
HP = Torque X RPM / 5252
dankaristo, I'll borrow Chris's X with it's "horrible" torque and race you. We'll see who wins.
Again, too many people are worried about peak numbers alone. Compare that torque curve to one on a stock turbo X. Sure, peak numbers might be more on the stock turbo one; but also take notice to how quickly that torque falls down and keeps falling down on the graph.
Bottom line - While peak torque may not be astronomical, that torque is held fairly consistantly throughout the rpm's. When something like this happens, you make HP!
I totally agree with the fact that peak numbers aren't the only thing to look at, the fact it is holding that much torque all the way to redline is amazing! Basically the boost is slowly creeping up to counter the normal decline of torque as the RPM's rise. Once the boost is set to be stable over the entire RPM range the curves will look more normal.
If AMS can market a good solid fuel pump that isn't as loud as the Walboro but flows just as well or better and is a direct bolt in, you would have many buyers even if it was 50-100% more in cost.
Old Oct 8, 2008 | 11:25 PM
  #39
fastkevin's Avatar
How come you don't set your smoothing on 5?
Old Oct 10, 2008 | 06:57 AM
  #40
we could set the smoothing on 5 to make the line look more clean but it would still be the same graph just "look" better. We are comfortable having it on 3
Eric
Old Oct 10, 2008 | 07:04 AM
  #41
Sharkbite2000's Avatar
Time for a X they are making power now!
  #42
Rez90's Avatar
Vid of dyno pull?
Old Oct 10, 2008 | 09:03 AM
  #43
Precision's Avatar
Keep going guys. Lets see a vid.
Old Oct 10, 2008 | 07:01 PM
  #44
fastkevin's Avatar
Eric
There's more to it than "looking better". The "smoother" line gives a more accurate power number. The lower settings cause the erratic peaks(you can see in your graph) that boost the power reading inaccurately.
Old Oct 10, 2008 | 07:52 PM
  #45
Ivan@AMS's Avatar
Actually the smoother line gives you a dampened version of HP (less accurate) but may give you a better idea of the VE of the motor.
We use smoothing set on 3 which is right in the center of the range.
