'08 GSR - Trouble Shifting into Reverse!
Old Oct 11, 2008 | 06:32 PM
JTMartin's Avatar
Car will very very rarely shift into reverse on first try. Even shifting into second first won't help. I actually have to move the car forward a few inches before it will shift to reverse almost every time. Anyone else heard of this problem? My mitsu dealer is about to hear about it but I wanted to see if anyone else had seen it.
And not at all related to gears... my battery seems to also be a dud, as the car doesn't seem to have enough juice to start sometimes.
Old Oct 13, 2008 | 07:20 PM
blanknotice's Avatar
same problem here. I can shift into reverse on the first try about half the time. The other half I think it's engaged and let out the clutch, only to look like a dumbass grinding grinding gears, or it clearly won't engage. You're not alone!
Old Oct 14, 2008 | 04:22 AM
midwestX's Avatar
guys this is not how it should be because i dont have shifting problem at all. please take it to the dealer and rape the warranty
Old Oct 14, 2008 | 04:32 AM
mezzano1's Avatar
take your foot off the clutch than put the clutch back in then shift to rev.
Old Oct 14, 2008 | 07:30 AM
Papi4baby's Avatar
+1 this is what the manual says, and it works for me. Although i don't have this problem too often. Good luck bud.
Old Oct 14, 2008 | 11:20 PM
Jabjab's Avatar
all i do is put it in 4th and then it goes into reverse np
Old Oct 15, 2008 | 11:49 AM
linjy2's Avatar
i heard something about they used 1st and 3rd to make reverse gear?
so if i cant get it in reverse, i shift to 1st and 3rd then reverse and it goes in every time.
Old Oct 15, 2008 | 12:08 PM
PlayinWithFire's Avatar
put it in neutral... let the clutch out...push it back in... shift into reverse.
That always works for me.
