UICP?LICP Aluminum VS STAINLESS Steel
Old Dec 9, 2008 | 06:22 PM
GNR's Avatar
GNR
Is there any differences between aluminum Vs Stainless Steel for UICP & LICP that most companies use?
Old Dec 9, 2008 | 06:28 PM
Sr20kidD's Avatar
weight
Old Dec 9, 2008 | 06:34 PM
tookinkee's Avatar
There is also a difference in the heat dissipation. If you ever weld anything that is where it is very apparent, along with the weight difference.
gsrboi80's Avatar
Strength
Old Dec 9, 2008 | 06:53 PM
GNR's Avatar
GNR
Thanks everyone... I`m asking because ETS. & Ultimate Racing all use Stainless Steel, while AMS, Etc uses Aluminum piping for its UCIP/LICP. So which ones r the best, stainless steel or Aluminum, whats the difference in weight?
Old Dec 9, 2008 | 06:54 PM
Rguy's Avatar
I dont think you will see any difference at all in 99 out of 100 tests of an aluminum vs a steel pipe in real world testing.
Go with what's the cheapest.
Old Dec 9, 2008 | 07:10 PM
SiC's Avatar
SiC
Aluminum = better heat dissipation and lighter
Stainless Steel = easier to to keep clean, more durable
Old Dec 9, 2008 | 08:34 PM
DC_TypeR's Avatar
^^ couldn't have said it any better.
Old Dec 9, 2008 | 08:54 PM
GNR's Avatar
GNR
tHANKS FOR THE INFO, YOU R A GREAT HELP...Aluminum is light, dissipate heat better. Stainless is more durable, easy to keep clean. How mach making it in Titanium instead...
Old Dec 9, 2008 | 09:16 PM
cpoevo's Avatar
Better have a big bank account!!!!
Old Dec 9, 2008 | 10:03 PM
xtremeboost's Avatar
Funny you ask this . About 4 years ago a VERY good friend I have actually tested that out in a lab . His results where a difference of +- .04 degrees in temp . In other words in real word conditions you cannot tell . If anything the main reason why you would want aluminum in your X is because you actually want to keep from adding extra weight to the car - more so in the front of an already very front heavy car
Old Dec 10, 2008 | 04:30 AM
stokEd's Avatar
Exactly. Worrying about heat dissipation, etc... for this piece is wasted effort. The thing that I'd be asking about is fitment (i.e. how well everything "lines up") especially if you're looking to get a one-piece unit.
Old Dec 10, 2008 | 09:07 AM
ETS Michael's Avatar
I would also look at what other products you plan on running. If you plan on buying an intercooler or turbo kit from the same manufacture, it might be better to go with 1 manufacture over another.
When you buy different parts from different manufactures sometimes they do not line up correctly. The good thing about the Evolution X is most people only run the piping 1 way, so you should be in luck. It's something to consider though.
We recommend going with steel over aluminum because of durability. You can tighten the clamps on a steel pipe as tight as possible without bending or distorting the pipe. If you try that on an aluminum pipe, the pipe may bend or warp, causing a leak. Aluminum is not bad by any means, we do build an UICP/LICP in aluminum.. It's the same price as the stainless steel upgrade on our site. Just be careful when tightening the clamps.
Good Luck! If you have any questions let me know!
Thanks,
Michael
Old Dec 10, 2008 | 05:48 PM
GNR's Avatar
GNR
Thanks for all the good information everyone!!!
Old Dec 10, 2008 | 09:03 PM
jayevo23's Avatar
does it really matter what uicp you get it seems like they are all the same with the same hp gains? it seems people just choose based on company name
