Cosworth High Performance Head Gasket
Old Dec 15, 2008 | 09:59 PM
ablaze's Avatar
Question Cosworth High Performance Head Gasket
hi guys,
just wondering about those, was gonna order the MX1 cams, then noticed these. any real benefits to these? dyno gains? and what's the difference between the 1.1mm and 1.3mm size?
http://www.cosworthusa.com/store/pc/...&idproduct=368
http://www.cosworthusa.com/store/pc/...&idproduct=367
advice?
Old Dec 16, 2008 | 03:50 AM
tons0torque's Avatar
The thicker gaskets are going to lower compression slightly. This allows the factory bottom end to cope with the increased cylinder pressures of a tuned 4b11. As far as gains, you'll probably loose a little on the bottom end, but you can make up for it by turning up the boost on top considering the lower compression ratio. Lower compression = less knock and more boost.
Old Dec 16, 2008 | 01:53 PM
DRAG's Avatar
These motors have stupid low compression as is. This is a more efficient combustion chamber than the 4G and a better resistance to detonation. There should be no reason to want to lower compression IMO
Old Dec 16, 2008 | 05:05 PM
ablaze's Avatar
drag, but as tons0torque pointed out, getting the upgraded gaskets will lower compression? doesn't sound very good if I'm gonna lose low-end power.
the 1.1mm and 1.3mm - any difference in terms of performance/gains?
Old Dec 18, 2008 | 06:26 AM
countdokoo's Avatar
More aggressive cams equate to more heat which will promote detonation. As the heat in your combustion chamber increases, it is always a safer option especially in our climate to opt for lower compression gaskets which will help in reducing chamber temps.
Old Dec 18, 2008 | 07:06 AM
gunzo's Avatar
Aggressive cam timing has nothing to do with heat ..
overly high boost, too lean a mixture etc are usually the cause for high cylinder head temperatures ..
Old Dec 18, 2008 | 07:08 AM
gunzo's Avatar
They are usually meant for you to run high boost using bigger turbos .. it's always a tradeoff ..
You have no reason to change to a thicker head gasket if you're keeping the stock turbo ..
Old Dec 18, 2008 | 08:26 AM
BigT's Avatar
Also, since we have timing chains, its a good idea to run a slightly thicker head gasket once the head and/or the block is over shaved.
Old Dec 18, 2008 | 10:11 AM
Tractionlimit's Avatar
Can anyone do this math? What does 0.2mm equate to in comp/ratio decrease? How much additional boost might that allow?
Old Dec 18, 2008 | 03:29 PM
Talon_66's Avatar
An HKS 1.2mm = 9.0:1 CR
HKS 1.0mm= 9.1:1CR
HKS 1.5mm = 8.8:1CR
so a 1.1mm should be 9.05:1CR?
1.3mm 8.9:1CR?
Old Dec 18, 2008 | 06:05 PM
Robevo RS's Avatar
i think you want to have a skinnier gasket to make more compression.
As far as i know.
Old Dec 18, 2008 | 06:17 PM
Sr20kidD's Avatar
umm, evos have timing belts not chains.... unless im wrong but im 105% its a belt.
Old Dec 18, 2008 | 06:35 PM
Geo@SpeedClinic's Avatar
Evo X is a chain.
Old Dec 18, 2008 | 06:44 PM
DC_TypeR's Avatar
As far as i know.
The only time you want MORE compression is w/ ALL MOTOR set ups.
Boost - Lower the better.
Also, like Speedclinic stated :
The evo 1-9 are timing belts - 4G63 motors
The evo x is a timing chain 4B11t
Old Dec 18, 2008 | 07:16 PM
Sr20kidD's Avatar
Originally Posted by Geo@SpeedClinic
Evo X is a chain.
oh duh, im in the X sub forum
Me = pwned
