Air Flow Package
Old Dec 24, 2008 | 09:35 AM
Vivid Racing's Avatar
Air Flow Package
Agency Power upgrades right now, if you want to upgrade your Evo X's air flow this is a way to do it. Not only will you create more boost, cool the air, and keep it consistante you will make some power gains to your Evo X. The product that can best do that for you is going to be Agency Power. Because we make this product I can get it shipped out when you place the order. If you have any questions PM for additional questions that you may have.
A little bit about Agency Power:
Agency Power Industries LLC was developed out of the need to provide quality, functional, and fashionable racing products. Starting from sway bar endlinks for the Subaru WRX back in 2003, Agency Power now has over 200 part numbers for cars ranging from the STI, EVO, M3, 996, TC, and more. Based out of Chandler, Arizona, Agency Power has established itself as one the core aftermarket companies for Subaru WRX STI and Mitsubishi EVO products. With new focus on the Porsche and BMW market, Agency Power is constantly developing new functional and race proven products. With dealers worldwide, the AP brand is recognized globally. Working with top distributers and tuners in the USA, AP can be found in Singapore, England, Canada, Australia, South Africa, and other parts in the EU.
Agency Power FMIC!!! $670.00
As you step up the power level on your 2008+ Mitsubishi Evo X, having proper cooling efficiency is mandatory to maximize your vehicles performance. Street and track cars will heavily benefit from the use of our upgraded intercoolers. Agency Power has developed these complete intercooler replacements for your Mitsubishi Evo X with no modification needed.
The bar and plate intercooler core is designed to provide maximum cooling efficiency .The end tanks are aluminum and then precision welded to the thick racing cores. The ends of the intercoolers are designed to work with factory Evo X intercooler piping or Agency Power Intercooler piping supplied with the GT35R turbo kit. These have been tested and provide a 14 hp gain on a stock EVO X and are rated to 750 hp. The intercoolers retain the factory mounting positions and come in a polished finished.
Dimensions:
Length: 24 1/8"
Thickness: 3.5"
Height: 12"
Inlet/Outlet Diameter: 3"
Agency Power UICP!!! $300.00
Much like your rubber brake lines, intercooler hoses expand under boost pressure. This causes a drop in pressure and that results in a loss of power. To combat this, most people replace the factory intercooler pipe connectors with silicone hoses or a new complete hard pipe. Agency Power has taken the Mitsubishi EVO X intercooler piping one step further and has released the all new 1 piece upper intercooler pipe kit. The pipe connects from the top of the front mount intercooler end tank and is 1 piece all the way to the turbo pipe. The 1 piece aluminum pipe features a bracket to secure the intercooler pipe in the factory location. Utilizing mandrel bends, we designed the pipe to have a smooth air flow path without any restrictions. When installed, the intercooler pipe kit will fit securely with plenty of room for the factory engine cover. This kit is available with a diameter of 3 inches for improved air flow on higher horsepower cars. By installing this pipe kit, you will maintain boost pressure more efficiently, pick up throttle response, and gain horsepower. As tested on a Mustang AWD Dyno with our short ram intake kit, this setup made almost 30 all wheel horsepower.
The pipe kit includes new silicone couplers and clamps for a secure and stylish look. The intercooler pipes are available in polished, which also matches our short ram intakes and suction pipes. This part is a direct fit, however to retain your factory plastic radiator shroud, you will need to trim the inside for clearance.
Agency Power Manual Boost Controller!!! (Black or Blue) $90.00
Agency Power brand new Manual Boost Controller is now available for your turbocharged vehicle. Designed with performance, fitment, and style in mind, the AP MBC will give your turbo vehicle some much need horsepower with a couple of easy twists of the unique adjustment knob not seen on any other manual boost controller.
How does the AP MBC work? Simple! The MBC is a bleed valve design, which has you connecting the hoses on either side to the compressor and the wastegate of the turbo. The MBC controls the airflow through the valve by the adjusting knob. Loosen the knob and more air moves for higher boost pressure. Tighten the knob down and restrict the flow for less boost pressure.
The AP MBC includes 2 feet of 5/32 vacuum tubing, a flexible aluminum bracket that bolts to the MBC and has predrilled holes for universal fitment, and hardware.
~ If you have any questions on these wonderful products please feel free to contact me direct or call or any questions. I am here for you, and can assist you for any one of these parts. In order for these prices to work you have to contact me direct so I can get you the best price on shipping also. Tell them your from EvoM so I can help you with additional savings. PM me anytime.
Donovan
