Building a bullet proof 4B11
Old Jan 10, 2009 | 01:23 PM
  #46
rong.'s Avatar
Looks great! The new evo shall rule. Seems like a very good price for all the machine work that has to be done. Good job , and keep up the good work.
Old Jan 11, 2009 | 08:00 AM
  #47
KPerez's Avatar
Originally Posted by 4G63DSM
A new aluminum block LS1 is just as stout as the original iron block sbc, if not more so.... why do people automatically assume aluminum is so terrible?
It is not the material that matters, but the design.... no one ever mentions, the closed deck, 4g63, vs. semi-open design of the 4b11.. and reall, that is where the strength lies..
Could someone explain what the differences and benefits are between an open vs semi closed block are? I have no idea. Thanks.
Later, Ken
Old Jan 11, 2009 | 10:04 AM
  #48
Ivan@AMS's Avatar
Later, Ken
A semi open deck block has support for the sleeves at the top of the block. In this picture, you can see the supports at the deck that keep the sleeves from moving at all in the block.
An open deck block has no supports at the top for the sleeves. It relies on the sleeve staying in place due to the support from the bottom and the head pushing down on it.
A closed deck block has full support for the sleeves as in this picture.
Old Jan 11, 2009 | 11:27 AM
  #49
KPerez's Avatar
Thanks Ivan for the pic's; they are very informative. As a follow up, would you hazard a guess as to why Mitsu went to the semi closed rather than the closed design? To save weight? If the closed is the strongest, then why not go that route?
Later, Ken
Old Jan 11, 2009 | 03:14 PM
  #50
STi2EvoX's Avatar
AMS, doesn't the 4b11 have iron sleeves stock? I thought I remember reading that somewhere, but perhaps not. If not, then what are the stock sleeves made of? In addition to being made of a stonger material, are these upgraded sleeves thicker as well? Did the support tabs have to be shortened to fit these in, and would that have any compromise in support tab strength? Oh and last question, how much power do you guys think the 4b11 will be good for after this?
Old Jan 11, 2009 | 04:46 PM
  #51
EricJ@AMS's Avatar
The 4B11T is not sleeved from the factory. It uses a coating process to harden the wall surfaces. Only time will tell how much cylinder pressure the factory cylinder walls will be able to take before distortion and cracking will occur.
Old Jan 11, 2009 | 05:59 PM
  #52
STi2EvoX's Avatar
Interesting. What I was trying to get at was how much power the 4b11 will handle after the sleeving process that you guys do. Not that I ever plan on going this high, but is 1000 hp a possibility with a built block like this?
Old Jan 11, 2009 | 06:06 PM
  #53
4G63DSM's Avatar
Originally Posted by Ivan@AMS
[quoted images removed. Please see the above post.]
Best answer ever... and to elaborate a little further.. open deck blocks can have the cylinder liner shake like a cow bell under lots of detonation. this is bad.... clearly a closed deck will prevent this... somewhere in the middle is a semi-closed deck... with theses, the design will dictate the strength... well thought out supports can be just as good as a closed deck with significantly less weight and vastly superior cooling as a result of the additional coolant surrounding the cylinder...
Old Jan 12, 2009 | 03:56 AM
  #54
KPerez's Avatar
Thanks 4G63DSM for info! So the 4B11 may be just as strong as the 4G63 and have more potential durability due to enhanced cooling capacity? I guess AMS would take issue with this since they have sleeved the 4B11. In the end, only time will tell the tale on the limits the 4B11 can take.
Later, Ken
Old Jan 12, 2009 | 08:49 AM
  #55
Tim@AMSperformance's Avatar
Originally Posted by STi2EvoX
Looks badass! I'm confused about one thing though; what's the deal with the align honing process of the main journals? These are not even touched during the machining of the sleeves, so why do these need to be honed? I'm guessing some kind of distortion of the block occurs during the machining process, but you guys said that you brace the block so that no distortion can occur, so I'm not quite sure what's occuring here. Any info would be appreciated, thanks. Oh, and keep up the good work! Looks great!
The mains are line honed to verify that the machining has 100% not moved the mains. Also in many instances when installing main studs the bores change the slightest bit due to more clamp load. On the Nissan KA motors we run into this all of the time. That is why we have to align hone all of them. As far as the 4b11 goes we are just taking that extra step to make sure that this is the highest quality block available.
Old Jan 12, 2009 | 01:17 PM
  #56
evo400's Avatar
Registered User
Eric the block we have lined had cast steel bores. Could you confirm that is the same spec US/UK .
Looking good so far .
Old Jan 13, 2009 | 12:24 PM
  #57
E7R's Avatar
E7R
Good question. Since there is no taller replacement block for a 4b11T like the 4g64, this would require someone like ERL to raised deck "Superdeck" style block, which they may or may not have plans on doing in the future. Raising the deck on a 4b11t would raise a few issues like replacement timing chain. Only time will tell.
NOT true,there is the 4b12:
Displacement 2.4 L (2359 cc)
Bore 88 mm
Stroke 97 mm
Compression ratio 10.5:1
Applications
* 2005 Mitsubishi Outlander
* 2007 Mitsubishi Delica
* 2008 Mitsubishi Lancer
* 2008 Citroën C-Crosser
* 2008 Peugeot 4007
Old Jan 13, 2009 | 04:07 PM
  #58
Aar0nsite's Avatar
Old Jan 13, 2009 | 09:49 PM
  #59
EricJ@AMS's Avatar
evo400, I just got done removing my foot from my own ***. Your right, the 4B11 does have casted in cast iron sleeves. Time will tell how strong they will be.
E7R, there are quite a few differences between the 4b11/4b12 and 4b11t blocks. We have yet to see a 4b12 to determine if it would be a suitable replacement for the 4b11t to handle very high horsepower applications.
Old Jan 13, 2009 | 10:32 PM
  #60
evovin's Avatar
I think the new 2010 Hyundai Genesis Coupe has 4B11 block too.?
