evo x rs turbo failure
Old Jan 7, 2009 | 04:46 AM
runovr 33's Avatar
Originally Posted by SiC
The shaft connects the intake & exhaust together. The shaft broke so the turbine wheel (exhaust) was spinning but the compressor side (intake) wheel stopped spinning.
sorry mate i ment were about's ie clean off shaft still in both bearing like mine
Old Jan 7, 2009 | 05:14 AM
Bimmubishi's Avatar
Were you running ALS?
Old Jan 7, 2009 | 06:03 AM
runovr 33's Avatar
bathurst 12 hr australia
Old Jan 7, 2009 | 06:30 AM
Bimmubishi's Avatar
Sounds awesome man. I'd love to see some pictures. I should have elaborated but I have my answer. I was abbreviating for Antilag. (ALS) Since you're endurance racing I'm assuming that there was none involved
Old Jan 7, 2009 | 06:43 AM
runovr 33's Avatar
that's right only mods permitted are shocks springs brakes same no of pistions roll cage seat data logging exhaust turbo back wheels some wheel track & radiator o and diff & g/box coolers
Old Jan 7, 2009 | 07:20 AM
Bimmubishi's Avatar
That's very similar to T2 here in the states for SCCA.
Old Jan 7, 2009 | 07:23 AM
runovr 33's Avatar
called 3e production car ovr here race on sunday buy on monday
Old Jan 7, 2009 | 09:21 AM
HybridKOOP's Avatar
Were you running gasoline at 7.5:1 AFR???
Old Jan 7, 2009 | 10:09 AM
TTP Engineering's Avatar
There are a number of users that have lost the stock turbo on the USDM version as well.
Old Jan 7, 2009 | 04:26 PM
gunzo's Avatar
That is why I am asking ..
Is that an Inconnell turbo or not ?
RS has Inconnell fitted as standard, GSR as an option (HA is standard)
I think USDM only use Inconnell ?? I'm not sure on this ..
Old Jan 7, 2009 | 05:25 PM
SiC's Avatar
SiC
When the dealer showed the owner they only showed him that the shaft was broken by just showing him the turbo. They didn't disassemble the turbo to show what part of the shaft broke so he doesn't seem to know. He did say that the dealer was spinning the exhaust blade so I guess the bearing was in tact.
Old Jan 7, 2009 | 07:28 PM
slonez's Avatar
lost a turbo on sunday at the track rear wheel fell apart running 24 psi flat boost line and 7.5 afr's motec logging on board both car's any one had a prob? have 3 rs's only 1 car did it !!
I know a guy here lost his turbo while doing dyno tuning, JDM GSR.
Old Jan 7, 2009 | 09:52 PM
I believe that I read that they are inconel in the states. I havent tested them though. Inconel is supposed to be able to take a VERY HIGH heat level, however it seems not enough in many cases (that is of course it is actually inconel on USDM units).
In the cases we have seen firsthand, the turbine blades deteriorate and disintegrate unbalancing the turbo and giving it a whurring sound. The turbine blade pieces can end up getting bounced back all the way to the cylinders and contact the spark plugs.
Old Jan 7, 2009 | 11:08 PM
runovr 33's Avatar
rs is titanium rear wheel gsr is inconiel pulled engine down to today another rear wheel failure screwed the engine but got another from ralliart and it's almost back in!
Old Jan 7, 2009 | 11:15 PM
runovr 33's Avatar
ha prefix is a titanium rear wheel. h is an inconel which comes on the gsr . and yes that's what seem's to be happeninig to me going to log egt's and back pressures next for more info! cheer's guy's
