dps and testpipes
Old Jan 16, 2009 | 05:55 PM
Deepseadiver's Avatar
It's been about a week since I have requested parts! I called and sent a few PM's on EVOX boards, but still no invoice and no way to pay.
One last question. Will the downpipe with the external O2 dump fit up to the existing cat? If not, will I need a special testpipe? (is it shorter or longer, the test pipe?)
Also do you sell a test pipe that is different? a normal one that will bolt up to existing downpipe and catback exhaust?
Sorry for all the questions, I just want to know what I am getting.
Old Jan 20, 2009 | 05:51 PM
dragon831's Avatar
^^^ what he said.
Also, anyone have a sound clip with an external dump?
Old Jan 20, 2009 | 06:40 PM
STi2EvoX's Avatar
Originally Posted by TTP Engineering
Buschur has tested the aftermarket downpipes to no gains and some losses even on 02 eliminator downpipes.
Testpipes are a piece of pipe.
We have a pipe coming to market soon we have just used to 12.02 @ 113mph.
While it is pretty common knowledge that the downpipe on the X doesn't add any power, every single test from every other company, including impartial 3rd party shops, have shown gains with the O2 housing/downpipe combo. Dave and I disagree on this, but I and many others think that it was very likely that the reason he showed no gains on that part was because A: it was an MR that was about at the limit of the TC SST's torque capacity, and B: the MR uses the airflow/torque limiter tables and airflow check tables in the ecu to communicate with the ecu in the tranny and will limit power output if the tables aren't adjusted or if the tranny is at it's limits.
Al at dynoflash also noted that an MR on his dyno with almost the exact same parts and power levels was experiencing clutch slippage. It is still unclear as to whether or not it was in fact clutch slippage, or if it was the ecu cutting power. Perhaps he can comment further on the issue. But again, every single test, including those from 3rd party shops and individuals with nothing to gain by promoting the product, have shown gains on GSRs. To the OP: do your research and decide for yourself.
Old Jan 20, 2009 | 06:47 PM
STItoEVOX's Avatar
^^woo! Great, thorough answer! And might I add, GREAT username also.
Old Jan 20, 2009 | 06:53 PM
STi2EvoX's Avatar
^Why thank you, screen name jacker! J/K
alex the great
May 23, 2013 11:38 AM
p1llar
Aug 30, 2011 12:43 PM
ronitlancer
19
Oct 23, 2009 11:17 AM
Clipse3GT
Jul 19, 2009 02:21 PM
johncy2000
Apr 20, 2006 06:26 PM
