drop in filter vs Cone
Old Jan 28, 2009 | 08:25 AM
CatalystGod's Avatar
Originally Posted by jls0711
my drop in filter just got here today and, flew to the auto store all excited picked it up came home and well... dropped it in!! felt the difference right away, so i took a quick drive to my buddies pad and when i drove away he called me and said that when i passed by his house he saw white smoke coming out of my exhaust and that it left a rotten smell in the air like sulfer???? so now i'm freaking out.. WHATS UP WITH THE WHITE SMOKE PRETTY SURE ITS NOT GOOD?????????any1
If it was cold outside, that's why he probably saw the smoke white. Best way to check is to replace with stock filter and see if its doing the same thing. If it still happens, get it to a dealer and have it checked out.
Old Jan 28, 2009 | 04:57 PM
jls0711's Avatar
after switching it back to the stock filter pretty much did the same thing as far as color of smoke and amount... and it was cold out probably 28 29degrees at the time we did the drives, makes the most amount of sense, the weather factor... i mean it just dont add up that a drop in filter would have anything to do with 1. the color of the smoke coming out of the exhaust& 2. the smoke in general... regardless the dealer idea is more than likely the thing to do, right on man
Old Mar 22, 2010 | 06:55 PM
ukie's Avatar
Did any of you have to tune for installing a cone filter? Or did you just slap it in and drive it? Any negative affects? Lean/rich?
Old Mar 22, 2010 | 07:13 PM
Nkryptd1's Avatar
As long as you leave your MAF attached you will run into no issues simply dropping the cone filter in. The MAF will adjust for the additional air flow.
Old Mar 24, 2010 | 04:26 PM
rmarte16's Avatar
same applies if i left the MAF sensor in on a custom intake? everything would be ok?
Old Mar 24, 2010 | 07:32 PM
SniperwolF's Avatar
im using the perrin drop in ... nt mch of a ... bt hopefully soon ill get my hand on one of those nice intake ...
Old Mar 24, 2010 | 08:51 PM
JDZNate's Avatar
Veteran: Air Force
I bought a Perrin drop-in filter last week and it works great. Better sound from the turbo and BOV aswell.
Old Mar 25, 2010 | 06:06 AM
ukie's Avatar
so you can hear the turbo and dv valve with just a
drop in filter??
Old Mar 26, 2010 | 08:14 AM
ukie's Avatar
is anyone running just a
cone filter on a stock tune? just wondering what the a/f ratio is at idle and at wot thanks
AllDayAnthony
Feb 7, 2015 08:24 AM
Jingming88
Apr 7, 2012 10:12 PM
RedEvoxGSR
Sep 25, 2011 02:41 AM
koach
15
Jan 23, 2010 08:45 AM
Thoe99
20
Jan 15, 2010 04:56 PM
