Sponsored by:
Sponsored by: CARiD
Drop in or cone filter?
Old Sep 23, 2011 | 03:13 AM
RedEvoxGSR's Avatar
Dont know which one to do? Putting in the drop in is what alot of ppl do and it works. But can i jus take the box out n put on a cone filter and get the same results?? Anybody that has done the cone, have u had problems or things to be careful about? Thanks!
Old Sep 23, 2011 | 03:54 AM
Jookies's Avatar
The cone will be better results with more sound but more expensive.
Old Sep 23, 2011 | 06:04 AM
RedEvoxGSR's Avatar
Cones arent that expensive.. Only like 60bucks.
Old Sep 23, 2011 | 06:10 AM
CaptainAsia's Avatar
Cone, just make sure to keep the snorkel on...
Old Sep 23, 2011 | 06:11 AM
Also make sure its tight enough where it won't pop off, that can skrew up the MAF sensor...
Old Sep 23, 2011 | 06:22 AM
laxplayer14's Avatar
if ur going with a cone, get a new silicone inlet tube as well (i.e cobb) the accordion inlet tube can actually cause fluctuations cause of the design
Old Sep 23, 2011 | 06:34 AM
RedEvoxGSR's Avatar
Then i might as well jus get an aftermarket intake! Are there any proven number of drop in vs a cone filter?
Old Sep 23, 2011 | 08:57 AM
acm_evo's Avatar
if you go the cone filter route, make sure you also shield it from the airflow of the electric fan to prevent erratic idle/stalls whenever the fan turns on.
Old Sep 23, 2011 | 01:51 PM
bmxking45's Avatar
I think I am gonna try the cone myself. I want some more turbo noise coming out from under that hood of mine!
Old Sep 24, 2011 | 06:41 PM
Gooseman396's Avatar
Open element filter will probably produce more power but be aware of the ac/heat issues. Its more of an annoyance but if its your dd either get a heat shield or keep the air box this will deflect the cooling fan trubulance that kills your idle and starting from a dead stop. Personally I went with the cobb sf and silicone inlet pipe very happy with the results just waiting for a good heat shield to block the turbulance
Old Sep 24, 2011 | 09:34 PM
RedEvoxGSR's Avatar
I will put on the cone and keep the snorkel!
Old Sep 25, 2011 | 02:41 AM
gotkamote's Avatar
I currently am using an AEM intake that utilizes the snorkel. I'm pretty sure there are other aftermarket intakes that use it as well. I like the AEM intake because I can hear the turbo spool and the stock BOV going off lol
gunhaha
May 22, 2014 03:11 PM
traitorzxiong
Feb 14, 2014 06:35 AM
bellorz
Apr 29, 2011 06:04 AM
Ltdanish07
23
Mar 26, 2010 08:14 AM
EvoX-LI
Evo X How Tos / Installations
16
Aug 28, 2009 02:55 PM
