Engine knock after exhaust and AccessPORT install
while this likely isn't the issue because you said you uninstalled the AP and still had the problem, but I didn't see it mentioned here that the stage 1 map is not for any mods.. it is for just a stock car... i'm sure you knew that, but just thought i'd throw it out there that if you are going to have an exhaust that you should either get to stage 2, or uninstall the AP and wait until you get the rest of the stuff to take it to stage 2 as it likely won't run correctly on stage 1 while you do have the exhaust.
The Stage 1 map says that it can be used with a cat back exhaust on an otherwise stock car, so I don't expect that to be an issue. As it turns out, I do have a leak in the exhaust where the center pipe connects to the muffler section. I had to order a new gasket which I don't have yet, but I expect this to be the cause of the sound I am hearing. We were also able to tweak the Stage 1 map to eliminate all of the knock that it was picking up. The car now feels like it is performing like it should. Thanks again for the suggestions, guys.
COBB Tuning
Apr 13, 2016 12:53 PM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
