New Deatsch Werks 800 cc injectors.
Old Feb 5, 2009 | 12:11 PM
HB Speed's Avatar
I have a Cobb intake so someof that may be different for others but it will get you close !
Old Feb 5, 2009 | 12:35 PM
goofygrin's Avatar
5.904*7000/1200 = 34% IDC? That's hella low. or am I off in what you're showing us?
Old Feb 5, 2009 | 12:52 PM
nala's Avatar
Any chance this can help with the "fuel dilution in oil problem"?
Old Feb 5, 2009 | 01:10 PM
HB Speed's Avatar
That is from the overly rich factory tune
Old Feb 5, 2009 | 01:14 PM
andrewzaragoza's Avatar
you are off. you are using the voltage which is wrong. should be the ipw at that rpm.
nala's Avatar
I certainly hope that that proves to be the case. But based on the other long thread on the fuel dilution issue, it seems that the few people with custom tunes that have had their oil analyzed are reporting the same high levels of fuel dilution...
I'm looking for anything that can help!
Old Feb 5, 2009 | 01:53 PM
goofygrin's Avatar
Right... the display he showed had V on the left and something in ms on the right. I figured it was ipw in ms... (figured wrong?)
Old Feb 5, 2009 | 03:08 PM
awddyno's Avatar
Nice. They look so much like the Subaru injectors.
I hope someone post a decent injector latency values. Its kinda time consuming when you have to reflash each setting to find out which one works best.
I will have to give these a try.
Old Feb 5, 2009 | 03:44 PM
SiC's Avatar
SiC
Look at the post above by HB Speed, he posted the scaling & latency info.
Thanks HB Speed
Old Feb 5, 2009 | 07:14 PM
dcasandman's Avatar
I can not wait to get some of these and a turbo.
Old Feb 5, 2009 | 09:18 PM
awddyno's Avatar
latency
Thanks HB Speed
He also mentioned he had a different intake. It will depend on how the latency was done. If it was done before the intake install then that would work.
I haven't seen a MAF scaling on the released version of Ecuflash, so I'm pretty sure the scaling for the different intake pipe was done through the latency and injector scaling. If ecuflash was used.
Old Feb 5, 2009 | 09:26 PM
SiC's Avatar
SiC
I thought the Cobb intake doesn't change the MAF housing (just a cone filter) so MAF scaling shouldn't be needed. With the cone filter the AFR may be slightly leaner but most people adjust that thru the fuel maps and not with injector scaling. So even if he dialed these injectors in with the Cobb intake, there should be a minimal difference when using a stock intake.
HB Speed's Avatar
Actually I loaded the stock maps with my scaling and injector latency and it was almost identical to my pre inj mapping all you should have to do is adjust fuel table to get wot right
Or a slight adjustment of latency or scalar if your intake is waaAy ofF
Old Feb 5, 2009 | 09:30 PM
awddyno's Avatar
I will try it when I get the injectors.
Old Oct 15, 2009 | 11:10 PM
Clipse3GT's Avatar
Originally Posted by DeatschWerks
The latency and scaler that HB speed posted has worked well for several customers we supplied the data to.
I'm a bit confused on the DW 800cc scaler.
My math:
New Scale Value = [(New Injector Size * Original Scale Value) / Original Injector Size]
709.33=[(800cc(static) x 532) / 600cc(static)]
ECUFLASH rounds this up to 713.
Is this correct?
