vacuum hose size?
Old Feb 28, 2009 | 04:55 AM
simons's Avatar
vacuum hose size?
How many mm is the vacuum hose that runs from intake manifold to factory BOV and the hose that runs from the compressor housing to the wastegate?
Old Feb 28, 2009 | 08:51 AM
boostin20's Avatar
It's 5/16"
Old Feb 28, 2009 | 01:33 PM
simons's Avatar
Originally Posted by boostin20
It's 5/16"
They're both 5/16"? Do you know what that equates to in mm?
Old Feb 28, 2009 | 01:43 PM
KGHtheII's Avatar
(5/16) inches = 7.9375 millimeters
Old Mar 3, 2009 | 12:55 PM
boostin20's Avatar
I hope you didn't buy the hose yet, I was thinking about something else when I posted. It's 7/32".
Old Mar 3, 2009 | 01:14 PM
KGHtheII's Avatar
(7/32) inches = 5.55625 millimeters
Old Mar 4, 2009 | 09:11 PM
shyong's Avatar
So does that mean I would purchase a 6mm vacuum hose?
Old Mar 5, 2009 | 05:31 AM
Levar's Avatar
Veteran: Army
Since we are talking about vacuum hoses, where would you fellahs recommend buying some from as the ones I have now stick together due to the heat I'm generating in the engine bay. I'm looking for some that are more durable as the ones I currently have were purchased from Ebay.
Old Jul 22, 2010 | 02:50 PM
GrnEVO's Avatar
This is an old thread, but I'm bringing it back from the dead to ask if anyone knows if this was the bore size (7/32") or if it is the wall size? I want to get Samco vacuum hoses and they only have 4mm (5/32"), 5mm (3/16"), 6.3mm (1/4") Which one should I go with? I know if it's too small then the vacuum will close the hose and if it's too large, well then I don't know what will happen, lol.
Old Dec 7, 2010 | 08:46 AM
bluepeartype-s's Avatar
Registered User
yes..this is old...sorry but, what are the hose sizes under the hood? 6mm and?
Does anyone just make a kit?
Thanks
Old Dec 7, 2010 | 09:26 AM
mlomker's Avatar
It isn't rocket science since vacuum hose stretches really well. I bought an assortment/kit from Jegs and I can vouch for the quality of the Trans Dapt hose that they sell. It obviously isn't the cheapest stuff around but the cheaper stuff usually has a harder outside and isn't as easy to work with.
http://tinyurl.com/2g73a5w
Old Dec 7, 2010 | 09:31 AM
Registered User
Thanks..I appreciate it...I just don't want this stuff getting too soft under the heat of engine bay.
-B
Old Dec 7, 2010 | 09:34 AM
mlomker's Avatar
If your hose is too close to heat sources then you might want to check out DEI's catalog. Cool Tape and some of their hose covering products might make sense for you.
Old Dec 7, 2010 | 05:32 PM
tjac357's Avatar
I got mine from Hi Performance Store. No complaints here.
http://www.hiperformancestore.com/
Old Dec 7, 2010 | 06:07 PM
blk-majik's Avatar
if the choice is between 5mm and 6mm, would it be best to go a little too large or too small? The only 7/32" I'm finding is made by Gates Racing and only comes in an ugly blue =/
