Evo X Clutch options.....
I really don't have time to test it since I'm getting my turbo (Dom 2) and cams (Cosworth MX1) installed this weekend. I just installed it in preperation for the upgrade.
From my experience, ACT is a transmission destroyer and always had lock out issues. That was one of the main reasons why i did the twin this time. I used a heavy duty with a 6 puck in my evo 8, and even tried the 6 puck sprung disc..i was changing tranny's like they were spark plugs..i also had a 6 puck on my 600whp integra..clutch would grab great but put a serious beating on the trans. And if you use a street disc (@ 450+whp), you'll never get into gear passed 6k RPM. But thats just my experience with ACT. Twin or Triple disc is the move if your planning on making decent whp and don't want to swap clutches/transmissions every 4 months
well i'm guessin that the multi plate clutches reduce shock to the drivetrain and has more hold with less pedal stiffness i think, but i'm usin a rps max series 6 puck clutch for my evo 8
Ive recently upgraded the basics, full intake, full exhaust, brake lines, FMIC, piping, and BOV. The shop that I had do the work has lead me to believe that my stock clutch is going to go at any moment because of the upgrades. Ive been looking in to all the options. My plan is to put a tune on her and then move on to the suspension and wheels. I was given word that the clutch to go with is the exedy twin plate, others such as the ACT and so on, are harsh to the rest of the transmission, also passed to me was that the install of the suggested clutch is quite involved, some what on the same level of organic chemistry. Im looking for feedback.
Are you refering to mis-alignment and hanging the tranny off the clutch while installing?
Later, Ken
Well , not only that but I've also seen some shops install both the fly wheel and pressure plate and NOT clean off the contact surfaces which glazes the disc and shortens its life .
so if i was having fly wheel and pressure plate installed at mitsu you think they will clean off the contact surfaces, or should i call and tell them to do it to be sure?
Will never again buy an ACT product. I was using the 6 puck sprung, clutch does not meet nor come close to the standard ACT claims it will, and will not honor anything close to its limited warranty. Thats my experience. That and $7 might buy you a coffee at starbucks.
