Boost Pill hurting performance on 91 octane??
Old Mar 8, 2009 | 06:16 PM
ice1874193's Avatar
http://blogs.edmunds.com/roadtests/2...nd-tuning.html
Can anyone comment on this? How does the pill perform on 93?
Old Mar 8, 2009 | 06:51 PM
spdracerut's Avatar
The 'boost pill' simply allows the stock boost control system to run more boost. On 91, we're just limited to the max boost we can run. I had to lower the boost around peak torque, 3.5k-4krpms on my VIII, because i was getting knock. I tried less timing, more fuel, nothing worked except turning down the boost.
Old Mar 8, 2009 | 08:58 PM
MY08GSRX's Avatar
get a stage 1 tuning running on 93 oct. Check the dyno forums, you'll see some cars with that set up with higher boost....
Old Mar 8, 2009 | 09:12 PM
stokEd's Avatar
If you're interested there are few threads in the Dyno Results forum (started by the Bryan, the tuner in that Edmund's blog):
https://www.evolutionm.net/forums/ev...ash-70whp.html
https://www.evolutionm.net/forums/ev...ly-pill-4.html
Old Mar 8, 2009 | 09:31 PM
EndlessRed's Avatar
you trust edmunds for tuning advice because...?
Old Mar 8, 2009 | 09:58 PM
DrasticK's Avatar
So whats the best option?
My tuner was talking about removing the boost pill instead of keeping it there or replacing it with the new one.
I need to do more reading on this subject
Old Mar 8, 2009 | 10:05 PM
spdracerut's Avatar
Bryan from GST did the tuning. They're very well versed in tuning Evos.
Old Mar 8, 2009 | 10:07 PM
spdracerut's Avatar
The boost pill simply allows the stock boost control system to run more boost. That's it, nothing more, nothing less.
Your fuel octane still defines the limit as to what boost level you can run.
Old Mar 8, 2009 | 10:23 PM
EndlessRed's Avatar
i know. i'm just saying why would you look at edmunds for any advice to start with *shrug* and if i'm reading it right, they're doing the tuning with just boost pill and nothing else.
Old Mar 8, 2009 | 10:28 PM
DrasticK's Avatar
So why would my tuner be talking of removing the pill altogether? What does the stock pill peak at vs a new one?
Old Mar 8, 2009 | 10:48 PM
CasperGSR99's Avatar
it doesnt "peak" it simply allows the peak boost to be held longer. the boost is controlled via ECU.
Old Mar 9, 2009 | 11:33 AM
JKav's Avatar
Edmunds' Evo X has just about all the bolt-ons you can get (IC, intake, TBE, Cossie cams). On 91 octane, it's simply at the limit of the stock turbo where more boost does more harm than good. That's all.
suprPHREAK
Toronto Lancer Club
Dec 25, 2014 07:09 AM
racer135
Mar 20, 2012 07:45 PM
lchu
Dec 5, 2011 11:44 AM
jonhix09RA
Sep 13, 2010 09:54 PM
mrfred
Oct 8, 2007 04:54 PM
