ABS checklite code: c102a
Old Mar 24, 2009 | 07:19 PM
clck's Avatar
Car: jdm evo x 5mt
Mod:stock
Had speedcut removed 1 month ago
Happen 3 days back right after tire pressure check at the pump
Launch X431 scanner shows c102a fault code, no check engine lite
Once code cleared, drive off on light throttle, there is shift shock sound from the rear and immediately abs check lite come on again.
All 4 abs sensor removed and clean, no visible damage
All fuses checked
Rom reflash back to stock
battery removed reset
Same thing happen
Gurus please help
Edit Again:
Found fault code C102a = malfunction RL speed sensor
Old Mar 25, 2009 | 09:52 AM
Rob@cobbtuning's Avatar
Move the sensors around and see if the code follows the sensor assuming RL == rear left and the sensors are not wheel depended like the BMWs.
Old Mar 25, 2009 | 03:39 PM
robh's Avatar
not to get off topic but how do you like the launchx431 scanner i was thinking about buying one in the very near future like next week
i currently have a snap-on verus witch is a great tool just thinking about the launch for its size and smaller jobs
Old Mar 25, 2009 | 07:07 PM
clck's Avatar
I don't like the Launchx431 price
It doesn't print the fault code in english, just a string of numbers.
Old Mar 26, 2009 | 03:46 AM
robh's Avatar
oh well i guess i better hold off and wait for them to improve it
thx for the reply
Old Mar 28, 2009 | 10:41 PM
clck's Avatar
Swap rear left n rear right wheel speed sensor
Fault code = c1035 = RR wheel speed sensor
Theory1:
Could be static from the air pump which kill the RL speed sensor
Thehighlander
Aug 9, 2015 10:36 AM
SlickDude
May 10, 2015 02:11 PM
foxbear2277
12
Dec 3, 2013 03:41 PM
veszett
Jan 24, 2010 07:14 PM
