who knows the reason for reverse problems?
Old Apr 24, 2009 | 05:36 PM
Project_Evo's Avatar
Originally Posted by lowkey
No.
It's better to do what others have said; put it in 1st then slip it into reverse. Sometimes you have to even let the clutch out slightly to just barely move the car before you push the clutch back in and then slip it into reverse. Try it, it works.
But, it sounds as if the OP has more serious problems, his car is a salvage, no telling what's screwed up inside the g'box.
Yea,
Its not a big issue with my X, but thanx for the tip I will def. have to try it out when I'm having issues.
Old May 27, 2009 | 07:29 PM
Tractionlimit's Avatar
If your car won't go into reverse at all, click here. This helped me A LOT.
